Eric Norum wrote:
Kazuro FURUKAWA wrote:
Hi Eric,
KEKB controls group analyzed the problem with PowerPC. They described
some details in
<URL:http://www.slac.stanford.edu/econf/C011127/TUAP048.pdf>
The problem analyzed and solved in the above paper is not the problem we
are seeing. The DTACK* signal is clean on our bus and is appearing well
after the VME-MXI-1 places data on the bus. The problem is that the
VME-MXI-1 module does not latch the A00-A31 lines. This results in the
following during a VME READ cycle:
1) CPU puts address information on bus and asserts AS*
2) CPU asserts DS0/1*.
3) VME-MXI-1 puts data on bus.
4) VME-MXI-1 asserts DTACK*.
5) CPU removes address information from bus and deasserts AS*.
6) VME-MXI-1 sees address lines change and puts scrambled data on bus.
7) CPU deasserts DS0/1* and latches in scrambled data........
tuning the universe's t27 parameter shortens 4->7 and may or may not
help... I had a problem with a Joerger VTR10012 where it helped.
-- Till
Note that no amount of delaying the DTACK* signal from the VME-MXI-1
will help this situation (since this affects only the time between steps
3 and 4 above -- and the problem is occurring at steps 5/6). The only
option is to replace all the address transceivers on the VME-MXI-1 with
latching transceivers and all the address and address modifier receviers
with latches. This is more board hacking than we want to get into.
- Re: National Instruments VME-MXI-1 modules vs. modern VME CPU modules Kazuro FURUKAWA
- Re: National Instruments VME-MXI-1 modules vs. modern VME CPU modules Eric Norum
CAEN V560 interchangeable with CAEN V260? Dayle Kotturi
ask the ext_pref-edm.tar file guobao shen
<2003>
Re: National Instruments VME-MXI-1 modules vs. modern VME CPU modules Till Straumann
<2003>
