1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Help about building a example under cygwin
To: "'guobao shen'" <[email protected]>
Cc: Jeff Hill <[email protected]>, [email protected]
Date: Fri, 14 Nov 2003 16:08:10 -0600
Jeff Hill wrote:
but there is a problem when I built  an example. My steps are:
1. perl makeBaseApp.pl -t example example
2. perl makeBaseApp.pl -i -t example example
3. make
I am less knowledgeable about makeBaseApp.pl than the authors so I am hoping that they have already contacted you about this. When I run makeBaseApp.pl with the win32-x86 build it seems to work correctly.
There is an option that you can give makeBaseApp if it can't find the path to Base, but that's not where the reported error message occurred:
> Can't find configure/RELEASE file at /jk/epics/base-3.14.4/configure/tools/convertRelease.pl line 79.
> make[1]: *** [checkRelease] Error 2
> make[1]: Leaving directory `/home/KEK J-PARC Group/iocs/configure'
> make: *** [configure.install] Error 2
It looks to me that the convertRelease.pl file doesn't like the spaces in your pathname '/home/KEK J-PARC Group/iocs/configure'. I can quite believe that this would cause other problems throughout the EPICS build system, so I suggest that you need to rename your 'KEK J-PARC Group' directory to something without spaces in it. Many Unix tools don't do the right thing when files or directory names contain spaces, and I don't think it's feasible to try and fix this.
- Andrew
There are 10 types of people in the world:
Those who understand binary, and those who don't.
RE: Help about building a example under cygwin Jeff Hill
Prev: Re: Help about building a example under cygwin Eric Norum
Next: Re: National Instruments VME-MXI-1 modules vs. modern VME CPU modules Kazuro FURUKAWA
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Help about building a example under cygwin Jeff Hill
Next: Re: Help about building a example under cygwin Eric Norum
