1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: syncronisation bettween records
To: [email protected]
Date: Mon, 10 Nov 2003 15:34:45 -0500
	Could you, please, explain me how can I do synchronization in
two next examples.
1. Detector has slow module, for example high voltage nodule, and ADC
digitizer module.
So I have two records (as minimum). SCAN field of ADC record is "I/O
Intr".
Situation is next. Operator changes voltage setting record of High
Voltage module.
ADC should wait until potential will be set. How can I do it?
2. Detector has amplifier with gain and ADC digitizer module.
Intr".
Situation is next. Operator can change gain during ADC is doing
measurement (for example,
ADC should take 200 samples, gain was changed on 100 samples). How can I
"freeze" gain?
Also I can find Record Reference Manual for Epics 3.13.7. Is there more
new manual?
Thanks, Andrei.
Re: syncronisation bettween records kuner
Prev: CA performance Liyu, Andrei
Next: Among the things for which I wish... Pete R Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: syncronisation bettween records kuner
