1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Command "seq" not found when running example ioc application
To: [email protected]
Cc: [email protected]
Date: Mon, 27 Oct 2003 07:09:39 -0600
[email protected] wrote:
I'm hoping someone can help me with what is probably a very simple problem.
We have completely reinstalled epics base (14.4.3 and 14.3.4) and the
sequencer (2.0.7) onto a clean Red Hat Linux 9.0 environment and are trying
to get the example application described in Getting Started in the IOC
Developer's Guide up and going.  We have followed the installation
instructions to the letter in order to build and run EPICS, the Sequencer
and the sncExample.st application.
When we run the example using the supplied st.cmd file, it all loads into
the iocsh correctly until it gets to the command:
seq sncExample,"user=username"
At this point, we get the error:
st.cmd -- Line 28 -- Command seq not found
Everything appears to have built OK and when we run the demo example that
comes with the sequencer, it executes correctly, including correctly
starting up the sequencer.  I presume from this that EPICS and the
sequencer have built OK.
We are using gmake version 3.79.1 and have tried 3.80.0 as well, with no
luck.
Can anyone out there tell me why the seq command is not found when I run
this application?
Steve Banks
Australian Synchrotron Project
Department of Infrastructure
Level 18, 80 Collins Street
Melbourne   VIC   3000
tel:  +613 9655 6303
fax:  +613 9655 8666
web: www.synchrotron.vic.gov.au
Are you sure you followed the instructions to edit the Makefile in myexampleApp/src as described in section 2.2.4 of the 02OCT2003 Application Developer's Guide?
When you build do you see the sequence program being built?
For example on linux I see
converting ../sncExample.stt
/home/phoebus/MRK/epics/modules/soft/seq/bin/linux-x86/snc ../sncExample.stt -o sncExample.c
Marty Kraimer
Command "seq" not found when running example ioc application Steven . Banks
Prev: Command "seq" not found when running example ioc application Steven . Banks
Next: Re: Command "seq" not found when running example ioc application Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
