I am seeking a bit of advice about using Ascii SIO (devAscii/drvAscii/drvSerial) and also alarm acknowledgement.
This is the first time I've done a job using Ascii SIO and am kinda new to EPICS anyway so I would like to know if there is any "accpeted wisdom" regarding the task I want to do.
I am using Ascii SIO to handle the serial comms with a magnet power supply. There are 8 commands that I send to the power supply which expect a response.
Originally I had set up my database so that a different command was being sent (via stringin records) every second. It turns out that the power supply can't be tusted to reply within one second. Occasionally a response from the power supply was arriving
late resulting in synchronisation being lost between the IOC and the power supply. So what I need to do is be able to recognise when I am in a late response situation.
Would it be a good idea to write a sequence program to implement the sending a command every second bit, and also use it to check for Read alarms on the stringin records to recognise late responses?
Can I easily ack alarms from a sequence program? Or, would it be a better idea to set the ACKT fields to No for my stringin records?
Also:
- Is there a way of ack'ing alarms from the ioc shell?
- Is there a list of which alarms are transient?
I am using EPICS base 3.14.2 and snc version 2.0.4.
Thanks, Damien.
Re: problem linking medm on Solaris 8, XRT/graph Mark Ito
RE: Ascii SIO and alarms questions Owens, PH (Peter)
<2003>
<2003>
