I have some problems on some devices with default EPICS motor record home speed (1000 steps/second) - too high. Since this seems to be hardcoded, I am tempted by the following suggestions: - home speed is configurable (I know that OMS card supports that option) - I rebuild the motor record for the concrete motors and change the default value. In this case I have to know where this is coded. Other suggestions from community regarding this issue will be welcome. I cannot write my own database doing it manually, as I in some cases have to refer to encoder reference position and not the home switch. Thanx! regards, Rok
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
