1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS to WAGO PLC using Ethernet MODBUS
To: Vladis Korobov <[email protected]>
Cc: [email protected]
Date: Tue, 09 Sep 2003 13:36:36 -0500
I have Ethernet-MODBUS support which is based on code obtained from the
Canadian Light Source. The CLS code is written to run on RTEMS and
supports Modicon PLCs.
I modified it to be OS independent, to work with 3.14.2 and to add
support for Siemens power meters.
John.
Vladis Korobov wrote:
> Hi all,
> I have to connect from EPICS to WAGO System PLC using MODBUS protocol (via Ethernet).
> Has anybody any software for such kind of communication?
> Any suggestions and advise will be appreciated,
> Vladislav Korobov
> MKS-2 Group, DESY
> Notkestr. 85
> 22607 Hamburg, Germany
> tel. +49 40 8998 3947
> e-mail:[email protected] or
>        [email protected]
Re: EPICS to WAGO PLC using Ethernet MODBUS Eric Williams
EPICS to WAGO PLC using Ethernet MODBUS Vladis Korobov
Prev: Re: The EPICS record field base attribute Marty Kraimer
Next: stale data monitor Vladimir Sirotenko
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: EPICS to WAGO PLC using Ethernet MODBUS Vladis Korobov
Next: Re: EPICS to WAGO PLC using Ethernet MODBUS Eric Williams
