1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS to WAGO PLC using Ethernet MODBUS
To: [email protected]
Date: Tue, 09 Sep 2003 11:52:09 -0400
We are running a modified version of the TRIUMF Modtcp code. It works with the Wago PLC under VxWorks on VME, EPICS 3.13.5.
Another version is running under Debian Linux Woody on X86 PC, EPICS 3.14.2.
We could send you the diff's for the Wago if you can get the TRIUMF Modtcp code from:
| Rolf Keitel, TRIUMF         Tel: (604) 222-7453 |
| Group Leader ISAC Controls  Fax: (604) 222-7307 |
| and Electronics Development                     |
| Vancouver, B.C., Canada                         |
Dr. Ivan So
NSLS, BNL
[email protected]
Prev: EPICS to WAGO PLC using Ethernet MODBUS Vladis Korobov
Next: The EPICS record field base attribute J. Frederick Bartlett
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS to WAGO PLC using Ethernet MODBUS Eric Williams
Next: Re: EPICS to WAGO PLC using Ethernet MODBUS Elder Matias
