I'm afraid this idea is a very long way from being as simple as it might seem, because of memory fragmentation issues. Marty has already posed the major issue - where are you going to save the values to put into the fields, especially as the data can be an array? To do that, you have to continually malloc and free memory, which currently only the Channel Access server does and then only when creating and destroying the tasks that maintain the network connection to a new client. There are no calls to memory allocation routines inside the database runtime engine, precisely because continually doing that leads to memory fragmentation. We need EPICS to be capable of building systems that have uptimes of many months or more, and memory fragmentation problems would kill that existing capability. Benjamin is right - we need to kill this gnat of a problem without blowing our own heads off in the process, which means a lot of thinking and testing of any radical changes. Marty does have a very good understanding of the issue, and is now proposing a relatively simple solution that reflects the caching nature of Channel Access (i.e. only the last value will be retained if the data target is busy). Anything more complex is not likely to be suitable for R3.14.x IMHO. - Andrew -- There are 10 types of people in the world: Those who understand binary, and those who don't.
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
