1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: building medm on RH9/RH Motif
To: tech-talk <[email protected]>
Date: Tue, 02 Sep 2003 12:48:42 -0400
Ran into a curious/painful situation where medm would build ok on one RH9 box but not on another RH9 box. The linker was complaining about undefined __ctype_b and __ctype_tolower. Originally it looked like the problems were in libca and libCom, but it turns that was a red-herring. The problem was that on one box /usr/X11R6/lib//libXm.so was a softlink to libXm.so.2.1 And on the other box [the one that linked successfully] had: libXm.so -> libXm.so.3.0.1
Both motif's were installed from the same CD, yet the links ended up differently.....summary if you get __ctype_b or __ctype_tolower undefines check your X libraries....
arne
Arne Freyberger Jefferson Lab Phone: (757) 269-6268 12000 Jefferson Avenue Pager: (757) 680-8884 [email protected]
Newport News, VA 23606 Phax: (757) 269-5800 http://casa.jlab.org
Prev: Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] Brian Bevins
Next: RE: [Fwd: Re: Does DISP work for DB OUT links? Related question] Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Home signal does not affect the .ATHM field of the motor record Rok Sabjan
Next: FW: Problem with seq 2.0.4 Mark Rivers
