Subject: |
Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] |
Brian Bevins <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 02 Sep 2003 11:32:09 -0400 |
Marty Kraimer wrote:
An additional comments on Jeff's second suggestion:
Fix 2:
There is a new field called AVAL (for asynchronous value) which is
initialized at the start of processing to what
is in the VAL field. When processing completes the AVAL field is used to
determine if monitors will be sent instead
of VAL.
This does seem like it should be easy to implement.
General Rule: Record support that allows asynchronous processing must do
this for any field for which it checks for value change before issuing
monitors.
Marty Kraimer
Does this really solve the original problem? When asynchronous
processing starts for the second put won't it overwrite what the first
put cpoied into AVAL?
Brian S. Bevins, PE
Computer Scientist / Mechanical Engineer
Thomas Jefferson National Accelerator Facility
- RE: [Fwd: Re: Does DISP work for DB OUT links? Related question] Jeff Hill
- Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] Marty Kraimer
- [Fwd: Re: Does DISP work for DB OUT links? Related question] Marty Kraimer
Re: Changes to records during asynch processing Marty Kraimer
building medm on RH9/RH Motif Arne P. Freyberger
<2003>
<2003>
