An additional comments on Jeff's second suggestion:
Fix 2:
There is a new field called AVAL (for asynchronous value) which is initialized
at the start of processing to what
is in the VAL field. When processing completes the AVAL field is used to
determine if monitors will be sent instead
of VAL.
This does seem like it should be easy to implement.
General Rule: Record support that allows asynchronous processing must do this
for any field for which it checks for value change before issuing monitors.
Marty Kraimer
- Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] Brian Bevins
- [Fwd: Re: Does DISP work for DB OUT links? Related question] Marty Kraimer
Re: Changes to records during asynch processing Marty Kraimer
Re: Changes to records during asynch processing Benjamin Franksen
<2003>
<2003>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
