1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Channel Access Errors
To: "'Gary P Carr'" <[email protected]>, <[email protected]>
Date: Mon, 25 Aug 2003 15:33:26 -0600
The server is complaining that it has received an undecipherable UDP message. I would take a close look at what is
occurring on xxxxxx.yyyyyy.lanl.gov.
o Possibly 3rd party software/hardware using UDP port 5064 that isn't CA.
o Possibly hosts that have failed their 10/100 auto negotiation or full/half duplex auto-negotiation, or possibly
some other MAC level packet damage that clobbers so many bits that the CRC checksum sanity tests do not reject the
damaged packet.
> We are using the version of the gateway built against
> patched EPICS 3.12.
Surely this is built against a patched EPICS R3.13?
PS: A new version of the CA gateway compatible with EPICS R3.14 and with many bug fixes will be available soon, but
I doubt that this will resolve the specific problem you are seeing.
I can drop by and take a look if you would like.
Jeff
> -----Original Message-----
> From: Gary P Carr [mailto:[email protected]]
> Sent: Monday, August 25, 2003 3:09 PM
> To: [email protected]
> Cc: [email protected]
> Subject: Channel Access Errors
> We've been getting these errors on our Channel Access Proxy Gateway for
> the
> last couple of days. We are using the version of the gateway built
> against
> patched EPICS 3.12. Use the gateway to provide access to the controls
> subnet from outside the control system. Only see these errors for two
> outside hosts. Other channel access through the gateway seems to work
> fine.
> I finally blocked access for the two hosts at our firewall. Had more
> than a
> Gig of log messages just like the following:
> CAS: bad message type=11
> CAS ? on ? at xxxxxx.yyyyyy.lanl.gov:5064: cmd=11 cid=4294967295 typ=0
> cnt=0 psz=40 avail=8e
> Internal failure - unexpected error processing stateless protocol
> Can't find a match to any of the strings in the errors in the gateway
> code
> itself. Anyone have an idea about what they mean?
Re: Channel Access Errors Brian McAllister
Channel Access Errors Gary P Carr
Prev: Channel Access Errors Gary P Carr
Next: Does DISP work for DB OUT links? Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Channel Access Errors Brian McAllister
