1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Datum (Bancomm) GPS glitches
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Tue, 29 Jul 2003 09:01:14 -1000
Thanks for the replies on the GPS glitches.  I guess I didn't state
enough in the previous mail.  The Datum GPS does have a hardware
latch, which you set by reading the most significant byte first.  It
is cleared by reading the least byte last.  Data is in 8-bit bytes,
two BCD digits in a byte, plus one or two status bytes.  I have
asked Symmetricom, the successor to Datum, if there is a possibility
that the hardware register could have a problem latching, similar
to what can happen in software.
As far as my reading goes, the best suggestion so far, by Andy
Foster, is to turn off interrupts while reading.  For a very little
bit of overhead, this sounds like a very good idea.  I may also
look at Jeff Hill's suggestion of plugging into drvTS.c so that the
EPICS timestamps come from the GPS.  Right now they come from the
on-board clock, which has very poor accuracy.
Thanks everyone,
Bill
William L. Cruise                             [email protected]
Electronics System Supervisor                   FAX:    808 885-7288
Canada-France-Hawaii Telescope                  Voice:  808 885-3121
65-1238 Mamalahoa Highway         http://www.cfht.hawaii.edu/~cruise
Kamuela, HI   96743
RE: Datum (Bancomm) GPS glitches Jeff Hill
Prev: Re: Datum (Bancomm) GPS glitches Andrew Johnson
Next: who maintains libezca ? Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
