1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Static binaries R3.14.2 linux RH8.0
To: "Arne P. Freyberger" <[email protected]>, [email protected]
Date: Tue, 22 Jul 2003 08:55:22 -0400
I have not found the problem with RH8 and static binaries and R3.14.2 but I have learned a few things.
a) all your libraries must be compiled with the same versions of all the other libraries. In this case I think the issue has to deal with different versions of the pthread libraries being used to compile some of the other libraries. Apparently RH8 has some issues with this, as I found several threads on web from people with similar problems [but no easy solution..other than rebuilding all you libraries].
b) RH9 and R3.14.2 produce functioning static binaries.....so I'll go with this....
Arne
Arne P. Freyberger wrote:
Before I start to fight this battle, I was wondering if anyone else has already fought this and won....
I'm building R3.14.2 on a linux RH8.0 box. The iocSh example runs just fine build with shared libraries [STATIC_BUILD=NO]. But I'd like to build static binaries so they can be simply copied to a pc104 card w/o chasing down all the shared libraries. With STATIC_BUILD=YES the iocSh example seg. faults upon iocInit.....gdb dump follows.
epics> iocInit()
    Program received signal SIG32, Real-time event 32.
    0x081667e6 in sigsuspend ()
    (gdb) where
    #0  0x081667e6 in sigsuspend ()
    #1  0x080fff91 in __pthread_wait_for_restart_signal ()
    #2  0x080ffdb7 in pthread_create ()
    #3  0x080f4e45 in epicsThreadCreate (name=0x81e06c9 "errlog",
    priority=10, stackSize=0, funptr=0x80e91d4 <errlogThread>, parm=0x0)
        at ../../../src/libCom/osi/os/posix/osdThread.c:363
    #4  0x080e9035 in errlogInitPvt (arg=0xbffff210) at
    ../../../src/libCom/error/errlog.c:322
    #5  0x080f4d09 in epicsThreadOnceOsd (id=0x820668c, func=0x80e8ed0
    <errlogInitPvt>, arg=0xbffff210) at
    ../../../src/libCom/osi/os/posix/osdThread.c:344
    #6  0x080e9086 in errlogInit (bufsize=0) at
    ../../../src/libCom/error/errlog.c:334
    #7  0x080e8869 in errlogPrintf (pFormat=0x81cf021 "Starting
    iocInit\n") at ..../../../src/libCom/error/errlog.c:107
    #8  0x0806eccd in iocInit () at ../iocInit.c:82
    #9  0x0806eb8c in iocInitCallFunc (args=0x826dbc8) at
    ../dbAccessRegister.c:68
    #10 0x0806d1c0 in iocsh (pathname=0x0) at ../iocsh.cpp:431
    #11 0x0804879c in main (argc=1, argv=0xbffff394) at
    ../casa-apf1Main.cpp:19
    #12 0x0815f8a6 in __libc_start_main ()
Other details:
RH8.0  linux
gcc version 3.2 20020903 (Red Hat Linux 8.0 3.2-7)
If anyone needs more information let me know.....
THANKS!
arne
Arne Freyberger Jefferson Lab Phone: (757) 269-6268 12000 Jefferson Avenue Pager: (757) 680-8884 [email protected]
Newport News, VA 23606 Phax: (757) 269-5800 http://casa.jlab.org
Arne Freyberger Jefferson Lab Phone: (757) 269-6268 12000 Jefferson Avenue Pager: (757) 584-6268 [email protected]
Static binaries R3.14.2 linux RH8.0 Arne P. Freyberger
Prev: Applications Software Engineer paul heelas
Next: IOC to A-B Communication through Ethernet Paul M. Morris
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Static binaries R3.14.2 linux RH8.0 Arne P. Freyberger
Next: channel archiver on 3.14 Steven Hunt
