BAAAHHH!!!
Ignore my previous message! My previous tests of the speed of the replies
from the motor controller were misleading. Replacing it with a loopback
connector allows the serial "communications" to run as fast as I can drive
them with no unexpected delays. The delay must be introduced by the motor
controller, not by the code running in the IOC.
Dr. Russell O. Redman
Tel: (250) 363-6917 | Fax: (250) 363-0045
<mailto:[email protected]>
National Research Council Canada | Conseil national de recherches Canada
5071 West Saanich Road | 5071 West Saanich Road
Victoria, B. C. V9E 2E7 | Victoria, C.-B. V9E 2E7
Government of Canada | Gouvernement du Canada
> -----Original Message-----
> From: Redman, Russell O. [mailto:[email protected]]
> Sent: Friday, 2003 July 04 3:38 PM
> To: Tech-Talk (E-mail)
> Cc: 'Honey, Allan'; Dunn, Jennifer; Wooff, Robert
> Subject: overheads in serial communications with drvAscii, sioSup &
> tnetDe v
> This is probably one for Allan Honey to consider, but may be of wider
> interest.
> I am experiencing very large overheads using serial
> communications to talk
> to a motor controller. I am using drvAscii v2.2 with sioSup
> and tnetDev to
> communicate over a serial line to a motor controller. The
> hardware layout
> is :
> ioc --(Ethernet)-- terminal server --(19200)-- controller
> where I am using sioSup and tnetDev to connect to a specified
> port on a
> terminal server, which is configured to talk at 19200 baud to the
> controller. The IOC an MVME2402-3, a PowerPC running VxWorks
> 5.4 and EPICS
> R3.13.5.
> I am passing short messages both ways across this link, 10
> characters max
> each way. At 19200 baud, the line should pass about 2000
> characters each
> second, so the whole prompt/response sequence should be
> complete in about 10
> ms. In fact, it takes around 300 to 400 ms to complete.
> Till now, I have
> operated on the assumption that the PPC was so fast that the
> latency in
> serial communications would be dominated by the baud rate,
> but apparently
> not. After considerable testing, I am convinced that the
> controller is
> replying quite rapidly to each message and is not a
> significant source of
> delay. I am convinced at the 95% level that the delay is introduced
> somewhere in the serial driver/Ethernet connection.
> For example, if I set a single record to scan every 0.1
> seconds, it is able
> to process once every 4 tries:
> -> dbpf "conb:lo:gal:wrtst.TPRO","1"
> DBR_UCHAR: 1 0x1
> value = 0 = 0x0
> -> dbpf "conb:lo:gal:wrtst.SCAN",".1 second"
> DBR_STRING: .1 second
> value = 0 = 0x0
> -> process: conb:lo:gal:wrtst
> active: conb:lo:gal:wrtst
> (etc...)
> An interesting variation is to forward link two records
> conb:lo:gunn:x:rx.FLNK = conb:lo:gunn:x:px
> -> dbpf "conb:lo:gunn:x:px.TPRO","1"
> DBR_UCHAR: 1 0x1
> value = 0 = 0x0
> -> dbpf "conb:lo:gunn:x:rx.TPRO","1"
> DBR_UCHAR: 1 0x1
> value = 0 = 0x0
> -> dbpf "conb:lo:gunn:x:rx.SCAN","Passive"
> DBR_STRING: Passive
> value = 0 = 0x0
> -> dbpf "conb:lo:gunn:x:rx.SCAN",".1 second"
> value = 0 = 0x0
> -> process: conb:lo:gunn:x:rx
> active: conb:lo:gunn:x:rx
> process: conb:lo:gunn:x:px
> process: conb:lo:gunn:x:rx - repeat block
> active: conb:lo:gunn:x:rx |
> process: conb:lo:gunn:x:px - end block
> (etc...)
> In this case, rx is able to queue a message at the start of
> the block but
> must wait for both the previous px message and its own
> message to complete
> before it finishes processing and triggers px again. The
> pair of messages
> take about 700 ms to complete.
> Needless to say, this overhead is unacceptably large.
> I have no idea where to begin looking for such large overheads in the
> drvAscii/sioSup/tnetDev combination, nor even whether this is the real
> source of the problem. Any ideas what might be wrong?
> recherches Canada
overheads in serial communications with drvAscii, sioSup & tnetDe v Redman, Russell O.
RE: EPICS collaboration meeting presentations Chestnut, Ronald P.
<2003>
StripTool Steven Hunt
<2003>
