1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: R3.14 and registerRecordDeviceDriver
To: Kate Feng <[email protected]>, [email protected]
Date: Tue, 24 Jun 2003 09:41:51 +0200
Hi Kate and all others,
Kate Feng wrote:
> ... My wish also gives RTEMS or Linux users an option to dynamically
> load a new application code (e.g. ld("new.obj")), which might need a
> new record/device/driver support entry table registered (e.g.
> new_SRCS += new_registerRecordDeviceDriver.cpp) at run time or even
> during an IOC test/development stage, which could occur very often
> during a development cycle. I actually found it handy in beamline
> applications.
Attached you will find a Linux (UNIX?) implementation of the 'ld'
command. Just link it to your iocsh. On Linux, it can load shared libraries (*.so). Maybe the code has to be modified to run on other platforms. I used the 'dlopen' function to implement it.
ld ("foo")
Searches LD_LIBRARY_PATH for libfoo.so, foo.so, foo (in this order).
After loading the code, all C++ constructors of global objects are executed (for registering, etc.)
I have not tried it on any other platform.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
* ld - load code dynamically
* $Author$
* $ID$
* $Date$
* DISCLAIMER: Use at your own risc and so on. No warranty, no refund.
#include <iocsh.h>
#include <stdio.h>
#include <dlfcn.h>
/* ld (dynamicLibrary) */
static const iocshArg ldArg0 = { "library", iocshArgString };
static const iocshArg * const ldArgs[1] = { &ldArg0 };
static const iocshFuncDef ldFuncDef = { "ld", 1, ldArgs };
static void ldCallFunc (const iocshArgBuf *args)
#ifdef UNIX
    char libname[256];
    if (!args[0].sval)
        fprintf (stderr, "missing library name");
        return;
    sprintf (libname, "lib%.249s.so", args[0].sval);
    if (dlopen (libname, RTLD_NOW|RTLD_GLOBAL)) return;
    sprintf (libname, "%.252s.so", args[0].sval);
    sprintf (libname, "%.255s", args[0].sval);
    fprintf (stderr, "%s\n", dlerror());
#else
    fprintf (stderr, "not supported for this operating system");
#endif
class IocshRegister {
public:
    IocshRegister (const iocshFuncDef& piocshFuncDef, iocshCallFunc func) {
        iocshRegister (&piocshFuncDef, func); }
static IocshRegister register_ld (ldFuncDef, ldCallFunc);
Re: R3.14 and registerRecordDeviceDriver Kate Feng
Prev: Re: R3.14 and registerRecordDeviceDriver Kate Feng
Next: EPICS collaboration meeting presentations Hayton, TG (Tim)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: R3.14 and registerRecordDeviceDriver Kate Feng
