1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: fd_caMotif build can't find Xm includes
To: Steven Hartman <[email protected]>
Cc: [email protected]
Date: Wed, 11 Jun 2003 10:52:33 -0700
The include files are there. The -l option is not in the gcc command line. But it wasn't on the RH 8 system, either, and that built OK. Where in the build configuration should the option be added?
At 01:44 PM 6/11/2003 -0400, Steven Hartman wrote:
On Wed, 11 Jun 2003, Eric Williams wrote:
> I'm building an IOC under Linux (Red Hat 7.3) and the make is blowing up
> while compiling fd_caMotif because it can't find the Motif include files,
I'm working on a similar setup right now. openmotif-devel provides
/usr/X11R6/include/Xm/Xm.h. Is this file on your system? If not, you have
a problem with the installation of that rpm. If so, is make passing
-I/usr/X11R6/include to gcc? If not, you have a problem in your epics
build configuration.
Steve Hartman
[email protected] | 919-660-2650
Duke Free Electron Laser Laboratory
Re: fd_caMotif build can't find Xm includes Steven Hartman
fd_caMotif build can't find Xm includes Eric Williams
Prev: Re: fd_caMotif build can't find Xm includes Eric Williams
Next: Re: fd_caMotif build can't find Xm includes Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: fd_caMotif build can't find Xm includes Steven Hartman
