I'm trying to understand the cause of sporadic but consistent CA write failures. The records in question are typically written every few hours and are spread across 12 IOCs. I have not been able to identify a pattern with the with failures in terms of one write failing consistently. About a month ago I did discover that the client that writes to these records was not calling CA poll at least every 15 seconds as specified in the CA manual. For the last month the client calls CA poll once a second and the problems persist. Any suggestions on where to look? Thanks Geoff
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
