1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: converRelease.pl
To: Steve Hunt <[email protected]>
Cc: [email protected]
Date: Mon, 26 May 2003 11:20:48 -0400
Hi Steve,
I miss understood the question.
Kay Kasemir has changed our version to allow this.
I will send this to you and Janet in a separate e-mail.
Ernest
On Mon, 2003-05-26 at 11:06, Ernest L. Williams Jr. wrote:
> Hi Steve,
> I think Janet Anderson has this fixed in R3.14.2.
> I have justed completed the build for R3.14.2 on Red Hat Linux 9.0
> Janet, is there a patch available for R3.14.1?
> Thanks,
> Ernest
> On Mon, 2003-05-26 at 11:01, Steve Hunt wrote:
> > Hi all,
> > In 3.14.1,  the script base/configure/tools/convertRelease.pl  seems to
> > expand configuration files (like configue/RELEASE), to create files to
> > be included in make for a particular application and architecture.
> > Unfortunately it does not take account of any environment variables, so
> > if you set EPICS_BASE in your environment it will be ignorred and the
> > value from your configuration files will be taken, or the build will
> > fail if they are not defined.
> > This is causing us a problem, as we don't want to manualy edit these
> > files every time we build epics in a different location (we are trying
> > to speed up, and generalize our  installation and build procedures).
> > Should this perl script be modified ? ( I can't do this as I can't even
> > spell pearl!).
> > Thanks in advance
> > Steve Hunt
Ernest L. Williams Jr. <[email protected]>
converRelease.pl Steve Hunt
Re: converRelease.pl Ernest L. Williams Jr.
Prev: Re: converRelease.pl Ernest L. Williams Jr.
Next: Re: convertRelease.pl Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
