In 3.14.1, the script base/configure/tools/convertRelease.pl seems to expand configuration files (like configue/RELEASE), to create files to be included in make for a particular application and architecture. Unfortunately it does not take account of any environment variables, so if you set EPICS_BASE in your environment it will be ignorred and the value from your configuration files will be taken, or the build will fail if they are not defined. This is causing us a problem, as we don't want to manualy edit these files every time we build epics in a different location (we are trying to speed up, and generalize our installation and build procedures). Should this perl script be modified ? ( I can't do this as I can't even spell pearl!). Thanks in advance Steve Hunt
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
