EPICS R3.14 Channel Access Reference Manual
Jeffrey O. Hill
Los Alamos National Laboratory
SNS Division
Copyright © 2002 The University of Chicago, as Operator of
Argonne National Laboratory.
Copyright © 2002 The Regents of the University of California, as Operator of
Los Alamos National Laboratory.
EPICS BASE Versions 3.13.7 and higher are distributed subject to a Software
License Agreement found in the file LICENSE that is included with this
distribution.
Modified on $Date: 2003/05/21 23:17:09 $
Table of Contents
Functionality Index
Deprecated Function Call Interface Function Index
Configuration
Why Reconfigure Channel Access
Typically reasons to reconfigure EPICS Channel Access:
- Two independent control systems must share a network without fear of
interaction
- A test system must not interact with an operational system
- Use of address lists instead of broadcasts for name resolution and
server beacons
- Control system occupies multiple IP subnets
- Nonstandard client disconnect time outs or server beacon intervals
- Specify the local time zone
- Transport of large arrays
All Channel Access (CA) configuration occurs through EPICS environment
variables. When searching for an EPICS environment variable EPICS first looks
in the environment using the ANSI C getenv() call. If no matching variable
exists then the default specified in the EPICS build system configuration
files is used.
Name |
Range |
Default |
EPICS_CA_ADDR_LIST |
{N.N.N.N N.N.N.N:P ...} |
<none> |
EPICS_CA_AUTO_ADDR_LIST |
{YES, NO} |
YES |
EPICS_CA_CONN_TMO |
r > 0.1 seconds |
30.0 |
EPICS_CA_BEACON_PERIOD |
r > 0.1 seconds |
15.0 |
EPICS_CA_REPEATER_PORT |
i > 5000 |
5065 |
EPICS_CA_SERVER_PORT |
i > 5000 |
5064 |
EPICS_CA_MAX_ARRAY_BYTES |
i >= 16384 |
16384 |
EPICS_TS_MIN_WEST |
-720 < i <720 minutes |
360 |
Environment variables are set differently depending on the command line
shell that is in use.
C shell |
setenv EPICS_CA_ADDR_LIST 1.2.3.4 |
bash |
export EPICS_CA_ADDR_LIST=1.2.3.4 |
vxWorks shell |
putenv ( "EPICS_CA_ADDR_LIST =1.2.3.4" ) |
DOS command line |
set EPICS_CA_ADDR_LIST=1.2.3.4 |
Windows NT / 2000 / XP |
control panel / system / environment tab |
CA and Wide Area Networks
Normally in a local area network (LAN) environment CA discovers the
address of the host for an EPICS process variable by broadcasting frames
containing a list of channel names ( CA search messages ) and waiting for
responses from the servers that host the channels identified. Likewise CA
clients efficiently discover that CA servers have recently joined the LAN or
disconnected from the LAN by monitoring periodically broadcasted beacons sent
out by the servers. Since hardware broadcasting requires special hardware
capabilities, we are required to provide additional configuration information
when EPICS is extended to operate over a wide area network (WAN).
Channel Access is implemented using internet protocols (IP). IP
addresses are divided into host and network portions. The boundary between
each portion is determined by the IP netmask. Portions of the IP address
corresponding to zeros in the netmask specify the hosts address within an IP
subnet. Portions of the IP address corresponding to binary ones in the
netmask specify the address of a host's IP subnet. Normally the scope of a
broadcasted frame will be limited to one IP subnet. Addresses with the host
address portion set to all zeros or all ones are special. Modern IP kernel
implementations reserve destination addresses with the host portion set to
all ones for the purpose of addressing broadcasts to a particular subnet. In
theory we can issue a broadcast frame on any broadcast capable LAN within the
interconnected internet by specifying the proper subnet address combined with
a host portion set to all ones. In practice these "directed broadcasts" are
frequently limited by the default router configuration. The proper directed
broadcast address required to reach a particular host can be obtained by
logging into that host and typing the command required by your local
operating environment. Ignore the loop back interface and use the broadcast
address associated with an interface connected to a path through the network
to your client. Typically there will be only one Ethernet interface.
UNIX |
ifconfig -a |
vxWorks |
ifShow |
Windows |
ipconfig |
IP ports are positive integers. The IP address, port number, and protocol
type uniquely identify the source and destination of a particular frame
transmitted between computers. Servers are typically addressed by a well
known port number. Clients are assigned a unique ephemeral port number during
initialization. IP ports below 1024 are reserved for servers that provide
standardized facilities such as mail or file transfer. Port number between
1024 and 5000 are typically reserved for ephemeral port number
assignments.
The two default IP port numbers used by Channel Access may be
reconfigured. This might occur when a site decides to set up two or more
completely independent control systems that will share the same network. For
instance, a site might set up an operational control system and a test
control system on the same network. In this situation it is desirable for the
test system and the operational system to use identical PV names without fear
of collision. Usually the best choice is to assign new port numbers to the
operational system and allow the test system to use the default CA
port numbers. A site might also configure the CA port numbers because
some other facility is already using the default port numbers.
Purpose |
Default |
Environment Variable |
CA Server |
5064 |
CA Beacons (sent to CA repeater daemon) |
5065 |
If a client needs to communicate with two servers that are residing at
different port numbers then an extended syntax may be used with the
EPICS_CA_ADDRESS_LIST environment variable. See WAN
Environment below.
When the CA client library connects a channel it must first determine the
IP address of the server the channels Process Variable resides on. To
accomplish this the client sends name resolution (search) requests to a list
of server destination addresses. These server destination addresses can be IP
unicast addresses (individual host addresses) or IP broadcast addresses. Each
name resolution (search) request contains a list of Process Variable names.If
one of the servers reachable by this address list knows the IP address of a
CA server that can service one or more of the specified Process Variables,
then it sends back a response containing the server's IP address and port
number.
During initialization CA builds the list of server destination addresses
used when sending CA client name resolution (search) requests. This table is
initialized by introspecting the network interfaces attached to the host. For
each interface found that is attached to a broadcast capable IP subnet, the
broadcast address of that subnet is added to the list. For each point to
point interface found, the destination address of that link is added to the
list. This automatic server address list initialization can be disabled if
the EPICS environment variable "EPICS_CA_AUTO_ADDR_LIST" exists and its value
is either of "no" or "NO". The typical default is to enable network interface
introspection driven initialization with "EPICS_CA_AUTO_ADDR_LIST" set to
"YES" or "yes".
Following network interface introspection, any IP addresses specified in
the EPICS environment variable EPICS_CA_ADDR_LIST are added to the list of
destination addresses for CA client name resolution requests. In an EPICS
system crossing multiple subnets the EPICS_CA_ADDR_LIST must be set so that
CA name resolution ( search requests ) frames pass from CA clients to the
targeted CA servers unless a CA proxy (gateway) is installed. The addresses
in EPICS_CA_ADDR_LIST may be dotted IP addresses or host names if the local
OS has support for host name to IP address translation. When multiple names
are added to EPICS_CA_ADDR_LIST they must be separated by white space. There
is no requirement that the addresses specified in the EPICS_CA_ADDR_LIST be a
broadcast addresses, but this will often be the most convenient choice.
C shell |
setenv EPICS_CA_ADDR_LIST "1.2.3.255 8.9.10.255" |
bash |
export EPICS_CA_ADDR_LIST="1.2.3.255 8.9.10.255" |
vxWorks |
putenv ( "EPICS_CA_ADDR_LIST=1.2.3.255 8.9.10.255" ) |
EPICS_CA_ADDRESS_LIST environment variable. Each host name or IP address in
the EPICS_CA_ADDR_LIST may be immediately followed by a colon and an IP port
number without intervening whitespace. Entries that do not specify a port
number will default to EPICS_CA_SERVER_PORT.
C shell |
setenv EPICS_CA_ADDR_LIST "1.2.3.255 8.9.10.255:10000" |
Frequently vxWorks systems boot by default with routes limiting access
only to the local subnet. If a EPICS system is operating in a WAN environment
it may be necessary to configure routes into the vxWorks system which enable
a vxWorks based CA server to respond to requests originating outside it's
subnet. These routing restrictions can also apply to vxWorks base CA clients
communicating with off subnet servers. An EPICS system manager can implement
an rudimentary, but robust, form of access control for a particular host by
not providing routes in that host that reach outside of a limited set of
subnets. See "routeLib" in the vxWorks reference manual.
If the CA client library does not see a beacon from a server that it is
connected to for EPICS_CA_CONN_TMO seconds then an state-of-health message is
sent to the server over TCP/IP. If this state-of-health message isn't
promptly replied to then the client will assume that the server is no longer
present on the network and disconnect. Disconnecting implies notification of
client side application programs via function callbacks. The parameter
EPICS_CA_CONN_TMO is specified in floating point seconds. The default is
typically 30 seconds. For efficient operation it is recommended that
EPICS_CA_CONN_TMO be set to no less than twice the value specified for
EPICS_CA_BEACON_PERIOD.
The CA client library will continuously attempt to connect any CA channels
that an application has created until it is successful. The library
periodically queries the server destination address list described above with
name resolution requests for any unresolved channels. Since this address list
frequently contains broadcast addresses, and because nonexistent process
variable names are frequently configured, or servers may be temporarily
unavailable, then it is necessary for the CA client library internals to
carefully schedule these requests in time to avoid introducing excessive load
on the network and the servers.
When the CA client library has many channels to connect, and most of its
name resolution requests are responded to, then it sends name resolution
requests at an interval that is twice the estimated round trip interval for
the set of servers responding, or at the minimum delay quantum for the
operating system - whichever is greater. The number of UDP frames per
interval is also dynamically adjusted based on the past success rate.
If name resolution requests are not responded to, then the client library
doubles the delay between name resolution attempts and reduces the number of
requests per interval. The delay between attempts is initially limited by a
maximum however, after some long interval, if the client library does not
receive any responses it stops sending name resolution attempts altogether
until it sees a beacon anomaly.
The CA client library continually estimates the beacon period of all
server beacons received. If a particular server's beacon period becomes
significantly shorter or longer then the client is said to detect a beacon
anomaly. When a client sees a beacon anomaly then it resumes search requests
but with a longer initial interval between requests than is used when the
application creates a channel. An initial delay based on the client's
ephemeral port number is also imposed before the first name resolution
request to avoid all clients responding to a beacon anomaly at the same
instant. The program "casw" prints a message on standard out each time that a
CA client will detect a beacon anomaly.
Two conclusions deserve special emphasis. First, if a client does not
see the server's beacons, then it will use additional network and server
resources sending periodic state-of-health messages. Second, if a client does
not see the server's beacons, then it may not connect to a newly introduced
server that was initially inaccessible if the client timed out attempting to
find it. The typical situation where a client would not see the server's
beacon might be when the client isnt on the same IP subnet as the server, and
the EPICS_CA_ADDR_LIST was modified to include a destination address for the
server, but the server's beacon address list was not modified so that it's
beacons are received by the client.
When several client processes run on the same host it is not possible for
all of them to directly receive a copy of the server beacon messages when the
beacon messages are sent to unicast addresses, or when legacy IP kernels are
still in use. To avoid confusion over these restrictions a special UDP
server, the CA Repeater, is automatically spawned by the CA client library
when it is not found to be running. This program listens for server beacons
sent to the UDP port specified in the EPICS_CA_REPEATER_PORT parameter and
fans any beacons received out to any CA client program running on the same
host that have registered themselves with the CA Repeater. If the CA Repeater
is not already running on a workstation, then the "caRepeater" program must
be in your path before using the CA client library for the first time. If a
host based IOC is run on the same workstation with standalone CA client
processes, then it is probably best to start the caRepeater process when the
workstation is booted. Otherwise it is possible for the standalone CA client
processes to become dependent on a CA repeater started within the confines of
the host based IOC. As long as the host based IOC continues to run there is
nothing wrong with this situation, but problems could arise if this host
based IOC process exits before the standalone client processes which are
relying on its CA repeater for services exit.
Note: Starting with EPICS R3.14 all of the libraries in the EPICS base
distribution rely on facilities built into the operating system to determine
the correct time zone. Nevertheless, several programs commonly used with
EPICS still use the original "tssubr" library and therefore they still rely
on proper configuration of EPICS_TS_MIN_WEST.
While the CA client library does not translate in between the local time
and the time zone independent internal storage of EPICS time stamps, many
EPICS client side applications call core EPICS libraries which provide these
services. To set the correct time zone users must compute the number of
positive minutes west of GMT (maximum 720 inclusive) or the negative number
of minutes east of GMT (minimum -720 inclusive). This integer value is then
placed in the variable EPICS_TS_MIN_WEST.
Time Zone |
EPICS_TS_MIN_WEST |
USA Eastern |
300 |
USA Central |
360 |
USA Mountain |
420 |
USA Pacific |
480 |
Alaska |
540 |
Hawaii |
600 |
Japan |
-540 |
Germany |
-120 |
United Kingdom |
0 |
The environment variable EPICS_CA_MAX_ARRAY_BYTES determines the size of
the largest array that may pass through CA. This parameter must be set
appropriately for both the CA client and the CA server. In EPICS R3.14 CA
maintains a free list of 16384 byte network buffers that are used for
ordinary communication. If EPICS_CA_MAX_ARRAY_BYTES is larger than
16384 then a second free list of larger data buffers is established when
clients request transportation of large arrays.
Name |
Range |
Default |
EPICS_CAS_SERVER_PORT |
i > 5000 |
EPICS_CAS_AUTO_BEACON_ADDR_LIST |
{YES, NO} |
EPICS_CAS_BEACON_ADDR_LIST |
{N.N.N.NN.N.N.N:P...} |
EPICS_CA_ADDR_LIST1 |
EPICS_CAS_BEACON_PERIOD |
r > 0.1 seconds |
15.0 |
EPICS_CAS_BEACON_PORT |
i > 5000 |
EPICS_CAS_INTF_ADDR_LIST |
<none> |
EPICS_CAS_IGNORE_ADDR_LIST |
<none> |
Server Port
The server configures its port number from the EPICS_CAS_SERVER_PORT
environment variable if it is specified. Otherwise the EPICS_CA_SERVER_PORT
environment variable determines the server's port number. Two servers can
share the same UDP port number on the same machine, but there are
restrictions - see a discussion of unicast addresses and
two servers sharing the same UDP port on the same host.
Server Beacons
The EPICS_CAS_BEACON_PERIOD parameter determines the server's beacon
period and is specified in floating point seconds. The default is typically
15 seconds. See also EPICS_CA_CONN_TMO and Dynamic Changes in the CA Client Library Search
Interval.
CA servers build a list of addresses to send beacons to during
initialization. If EPICS_CAS_AUTO_BEACON_ADDR_LIST has the value "YES" then
the beacon address list will contain at least the broadcast address of all
LAN interfaces found in the host and the destination address of all
point-to-point interfaces found in the host.
If EPICS_CAS_BEACON_ADDR_LIST is defined then its contents will be used to
augment this list. Individual entries in EPICS_CAS_BEACON_ADDR_LIST may
override the destination port number if ":nnn" follows the host name or IP
address there. Alternatively, if EPICS_CAS_BEACON_ADDR_LIST is not defined,
EPICS_CA_ADDR_LIST is defined, and EPICS_CAS_INTF_ADDR_LIST is not defined,
then the contents of EPICS_CA_ADDR_LIST will be used to augment the list.
Otherwise, the list is not augmented.
The EPICS_CAS_BEACON_PORT parameter specifies the destination port for
server beacons. The only exception to this occurs when ports are specified
in EPICS_CAS_BEACON_ADDR_LIST or possibly in EPICS_CA_ADDR_LIST. If
EPICS_CAS_BEACON_PORT is not specified then beacons are sent to the port
specified in EPICS_CA_REPEATER_PORT.
Binding a Server to a Limited Set of Network Interfaces
The parameter EPICS_CAS_INTF_ADDR_LIST allows a ca server to bind itself
to, and therefore accept messages only from, a limited set of network
interfaces (each specified by it's IP address). Specifically, UDP search
messages addressed to both the IP addresses in EPICS_CAS_INTF_ADDR_LIST and
also to the broadcast addresses of the corresponding LAN interfaces will be
accepted by the server. By default, the CA server is accessible from all
network interfaces configured into its host. In R3.14 and previous
releases the CA server employed by iocCore does not implemet this
feature.
Ignoring Process Variable Name Resolution Requests From Certain Hosts
Name resolution requests originating from any of the IP addresses
specified in the EPICS_CAS_IGNORE_ADDR_LIST parameter are not replied to.
In R3.14 and previous releases the CA server employed by iocCore does not
implemet this feature.
Client Configuration that also Applies to Servers
See also Configuring the Maximum Array Size.
See also Routing Restrictions on vxWorks
Systems.
acctst <PV name> [progress logging level] [channel duplication count]
[test repetition count] [enable preemptive callback]
Description
Channel Access Client Library regression test.
The PV used with the test must be native type DBR_DOUBLE or DBR_FLOAT, and
modified only by acctst while the test is running. Therefore, periodically
scanned hardware attached analog input records do not work well. Test failure
is indicated if the program stops prior to printing "test complete". If
unspecified the progress logging level is zero, and no messages are printed
while the test is progressing. If unspecified, the channel duplication count
is 20000. If unspecified, the test repetition count is once only. If
unspecified, preemptive callback is disabled.
catime <PV name> [channel count] [append number to pv name if true]
Description
Channel Access Client Library performance test.
If unspecified, the channel count is 10000. If the "append number to pv
name if true" argument is specified and it is greater than zero then the
channel names in the test are numbered as follows.
<PV name>000000, <PV name>000001, ... <PV name>nnnnnn
casw [-i <interest level>]
Description
CA server "beacon anomaly" logging.
CA server beacon anomalies occur when a new server joins the network, a
server is rebooted, network connectivity to a server is reestablished, or if
a server's CPU exits a CPU load saturated state.
CA clients with unresolved channels reset their search request scheduling
timers whenever they see a beacon anomaly.
This program can be used to detect situations where there are too many
beacon anomalies. IP routing configuration problems may result in false
beacon anomalies that might cause CA clients to use unnecessary additional
network bandwidth and server CPU load when searching for unresolved
channels.
If there are no new CA servers appearing on the network, and network
connectivity remains constant, then casw should print no messages at all.
caEventRate <PV name> [subscription count]
Description
Connect to the specified PV, subscribe for monitor updates the specified
number of times (default once), and periodically log the current sampled
event rate, average event rate, and the standard deviation of the event rate
in Hertz to standard out.
ca_test <PV name> [value to be written]
Description
If a value is specified it is written to the PV. Next, the current value
of the PV is converted to each of the many external data type that can be
specified at the CA client library interface, and each of these is formated
and then output to the console.
Verify that the broadcast addresses are identical on the server's host and
on the client's host. This can be checked on UNIX with "netstat -i" or
"ifconfig -a"; on vxWorks with ifShow; and on windows with ipconfig. It is
normal for the broadcast addresses to not be identical if the client and
server are not directly attached to the same IP subnet, and in this situation
the EPICS_CA_ADDR_LIST must be set. Otherwise, if the client and server are
intended to be on the same IP subnet, then the problem may be that the IP
netmask is incorrectly set in the network interface configuration. On most
operating systems, when the host's IP address is configured, the host's IP
subnet mask is also configured.
Verify that the client and server are using the same UDP port. Check the
server's port by running "netstat -a | grep nnn" where nnn is the port number
configured in the client. If you do not set EPICS_CA_SERVER_PORT or
EPICS_CAS_SERVER_PORT then the default port will be 5064.
Two servers can run on the same host with the same server port number, but
there are restrictions. If the host has a modern IP kernel it is possible to
have two or more servers share the same UDP port. It is not possible for
these servers to run on the same host using the same TCP port. If the CA
server library detects that a server is attempting to start on the same port
as an existing CA server then both servers will use the same UDP port, and
the 2nd server will be allocated an ephemeral TCP port. Clients can be
configured to use the same port number for both servers. They will locate the
2nd server via the shared UDP port, and transparently connect to the 2nd
server's ephemeral TCP port. Be aware however that If there are two server's
running on the same host sharing the same UDP port then they will both
receive UDP search requests sent as broadcasts, but unfortunately (due to a
weakness of most IP kernel implementations) only one of the servers will
typically receive UDP search requests sent to unicast addresses (i.e. a
single specific host's ip address).
See Dynamic Changes in the CA Client Library Search
Interval.
Many Berkley UNIX derived Internet Protocol (IP) kernels use a memory
management scheme with a fixed sized low level memory allocation quantum
called an "mbuf". Messages about "ENOBUFS" are an indication that your IP
kernel is running low on mbuf buffers. An IP kernel mbuf starvation situation
may lead to temporary IP communications stalls or reduced throughput. This
issue has to date been primarily associated with vxWorks systems where mbuf
starvation on earlier vxWorks versions is rumored to lead to permanent IP
communications stalls which are resolved only by a system reboot. IP kernels
that use mbufs frequently allow the initial and maximum number of mbufs to be
configured. Consult your OS's documentation for configuration procedures
which vary between OS and even between different versions of the same OS.
Contributing Circumstances
- The total number of connected clients is high. Each active socket
requires dedicated mbufs for protocol control blocks, and for any data
that might be pending in the operating system for transmission to Channel
Access or to the network at a given instant. If you increase the vxWorks
limit on the maximum number of file descriptors then it may also be
necessary to increase the size of the mbuf pool.
- The server has multiple connections where the server's sustained event
(monitor subscription update) production rate is higher than the client's
or the network's sustained event consumption rate. This ties up a per
socket quota of mbufs for data that are pending transmission to the
client via the network. In particular, if there are multiple clients that
subscribe for monitor events but do not call ca_pend_event() or ca_poll()
to process their CA input queue, then a significant mbuf consuming
backlog can occur in the server.
- The server does not get a chance to run (because some other higher
priority thread is running) and the CA clients are sending a high volume
of data over TCP or UDP. This ties up a quota of mbufs for each socket in
the server that isn't being reduced by the server's socket read system
calls.
- The server has multiple stale connections. Stale connections occur when
a client is abruptly turned off or disconnected from the network, and an
internal "keepalive" timer has not yet expired for the virtual circuit in
the operating system, and therefore mbufs may be dedicated to unused
virtual circuits. This situation is made worse if there are active
monitor subscriptions associated with stale connections which will
rapidly increase the number of dedicated mbufs to the quota available for
each circuit.
Related Diagnostics
- The EPICS command "casr [interest level]" displays information about
the CA server and how many clients are connected.
- The vxWorks command "inetstatShow" indicates how many bytes are pending
in mbufs and indirectly (based on the number of circuits listed) how many
mbuf based protocol control blocks have been consumed. The vxWorks
commands (availability depending on vxWorks version) mbufShow,
netStackSysPoolShow, and netStackDataPoolShow indicate how much space
remains in the mbuf pool.
- The RTEMS command "netstat [interest level]" displays network
information including mbuf consumption statistics.
Significant performance gains can be realized when the CA client library
doesn't wait for a response to return from the server after each request. All
requests which require interaction with a CA server are accumulated
(buffered) and not forwarded to the IOC until one of ca_flush_io, ca_pend_io,
ca_pend_event, or ca_sg_pend are called allowing several operations to be
efficiently sent over the network together. Any process variable values
written into your program's variables by ca_get() should not be referenced by
your program until ECA_NORMAL has been received from ca_pend_io().
If successful, the routines described here return the status code
ECA_NORMAL. Unsuccessful status codes returned from the client library are
listed with each routine in this manual. Operations that appear to be valid
to the client can still fail in the server. Writing the string "off" to a
floating point field is an example of this type of error. If the server for a
channel is located in a different address space than the client then the
ca_xxx() operations that communicate with the server return status indicating
the validity of the request and whether it was successfully enqueued to the
server, but communication of completion status is deferred until a user
callback is called, or lacking that an exception handler is called. An error
number and the error's severity are embedded in CA status (error) constants.
Applications shouldn't test the success of a CA function call by checking to
see if the returned value is zero as is the UNIX convention. Below are
several methods to test CA function returns. See ca_signal() and SEVCHK for more information on this
topic.
status = ca_XXXX();
SEVCHK( status, "ca_XXXX() returned failure status");
if ( status & CA_M_SUCCESS ) {
printf ( "The requested ca_XXXX() operation didn't complete successfully");
if ( status != ECA_NORMAL ) {
printf("The requested ca_XXXX() operation didn't complete successfully because \"%s\"\n",
ca_message ( status ) );
Arguments of type chtype specifying the data type you wish to transfer.
They expect one of the set of DBR_XXXX data type codes defined in
db_access.h. There are data types for all of the C primitive types, and there
are also compound (C structure) types that include various process variable
properties such as units, limits, time stamp, or alarm status. The primitive
C types follow a naming convention where the C typedef dbr_xxxx_t corresponds
to the DBR_XXXX data type code. The compound (C structure) types follow a
naming convention where the C structure tag dbr_xxxx corresponds to the
DBR_XXXX data type code. The following table provides more details on the
structure of the CA data type space. Since data addresses are passed to the
CA client library as typeless "void *" pointers then care should be taken to
ensure that you have passed the correct C data type corresponding to the
DBR_XXXX type that you have specified. Architecture independent types are
provided in db_access.h to assist programmers in writing portable code. For
example "dbr_short_t" should be used to send or receive type DBR_SHORT.
Structure of the Channel Access Data Type Space
CA Type Code |
Read / Write |
Primitive C Data Type |
Process Variable Properties |
DBR_<PRIMITIVE TYPE> |
RW |
dbr_<primitive type>_t |
value |
DBR_STS_<PRIMITIVE TYPE> |
R |
struct dbr_sts_<primitive type> |
value, alarm status, and alarm severity |
DBR_TIME_<PRIMITIVE TYPE> |
R |
struct dbr_time_<primitive type> |
value, alarm status, alarm severity, and time stamp |
DBR_GR_<PRIMITIVE TYPE> |
R |
struct dbr_gr_<primitive type> |
value, alarm status, alarm severity, units, display precision, and
graphic limits |
DBR_CTRL_<PRIMITIVE TYPE> |
R |
struct dbr_ctrl_<primitive type> |
graphic limits, and control limits |
DBR_PUT_ACKT |
W |
dbr_put_ackt_t |
Used for global alarm acknowledgement. Do transient alarms have to
be acknowledged? (0,1) means (no, yes). |
DBR_PUT_ACKS |
W |
dbr_put_acks_t |
Used for global alarm acknowledgement. The highest alarm severity
to acknowledge. If the current alarm severity is less then or equal
to this value the alarm is acknowledged. |
DBR_STSACK_STRING |
R |
struct dbr_stsack_string |
value, alarm status, alarm severity, ackt, ackv |
DBR_CLASS_NAME |
R |
dbr_class_name_t |
name of enclosing interface (name of the record if channel is
attached to EPICS run time database) |
Channel value arrays can also be included within the structured CA data
types. If more than one element is requested, then the individual elements
can be accessed in an application program by indexing a pointer to the value
field in the DBR_XXX structure. For example, the following code computes the
sum of the elements in a array process variable and prints its time stamp.
The dbr_size_n function can be used to determine the
correct number of bytes to reserve when there are more than one value field
elements in a structured CA data type.
#include <stdio.h>
#include <stdlib.h>
#include "cadef.h"
int main ( int argc, char ** argv )
struct dbr_time_double * pTD;
const dbr_double_t * pValue;
unsigned nBytes;
unsigned elementCount;
char timeString[32];
unsigned i;
chid chan;
double sum;
int status;
if ( argc != 2 ) {
fprintf ( stderr, "usage: %s <channel name>", argv[0] );
return -1;
status = ca_create_channel ( argv[1], 0, 0, 0, & chan );
SEVCHK ( status, "ca_create_channel()" );
status = ca_pend_io ( 15.0 );
fprintf ( stderr, "\"%s\" not found.\n", argv[1] );
return -1;
elementCount = ca_element_count ( chan );
nBytes = dbr_size_n ( DBR_TIME_DOUBLE, elementCount );
pTD = ( struct dbr_time_double * ) malloc ( nBytes );
if ( ! pTD ) {
fprintf ( stderr, "insufficient memory to complete request\n" );
return -1;
status = ca_array_get ( DBR_TIME_DOUBLE, elementCount, chan, pTD );
SEVCHK ( status, "ca_array_get()" );
fprintf ( stderr, "\"%s\" didnt return a value.\n", argv[1] );
return -1;
pValue = & pTD->value;
sum = 0.0;
for ( i = 0; i < elementCount; i++ ) {
sum += pValue[i];
epicsTimeToStrftime ( timeString, sizeof ( timeString ),
"%a %b %d %Y %H:%M:%S.%f", & pTD->stamp );
printf ( "The sum of elements in %s at %s was %f\n",
argv[1], timeString, sum );
ca_clear_channel ( chan );
ca_task_exit ();
free ( pTD );
return 0;
Certain CA client initiated requests asynchronously execute an application
supplied call back in the client process when a response arrives. The
functions ca_put_callback, ca_get_callback, and ca_add_event all request
notification of asynchronous completion via this mechanism. The
event_handler_args structure is passed by value to the
application supplied callback. In this structure the dbr field
is a void pointer to any data that might be returned. The
s tatus field will be set to one of the CA error
codes in caerr.h and will indicate the status of the operation performed in
the IOC. If the status field isn't set to ECA_NORMAL or data isn't normally
returned from the operation (i.e. put call back) then you should expect that
the dbr field will be set to a nill pointer (zero). The fields
usr , chid , and type are set to the
values specified when the request was made by the application.
typedef struct event_handler_args {
void *usr; /* user argument supplied with request */
chanId chid; /* channel id */
long type; /* the type of the item returned */
long count; /* the element count of the item returned */
const void *dbr; /* a pointer to the item returned */
int status; /* ECA_XXX status of the requested op from the server */
} evargs;
void myCallback ( struct event_handler_args args )
if ( args.status != ECA_NORMAL ) {
if ( args.type == DBR_TIME_DOUBLE ) {
const struct dbr_time_double * pTD =
( const struct dbr_time_double * ) args.dbr;
When the server detects a failure, and there is no client call back
function attached to the request, then an exception handler is executed
in the client. The default exception handler prints a message on the console
and exits if the exception condition is severe. Certain internal exceptions
within the CA client library, and failures detected by the SEVCHK macro may
also cause the exception handler to be invoked. To modify this behavior see
ca_add_exception_event().
If the Process Variable's server and it's client are colocated within the
same memory address space and the same host then the ca_xxx() operations
bypass the server and directly interact with the server tool component
(commonly the IOC's function block database). In this situation the ca_xxx()
routines frequently return the completion status of the requested operation
directly to the caller with no opportunity for asynchronous notification of
failure via an exception handler. Likewise, callbacks may be directly invoked
by the CA library functions that request them.
For routines that require an argument specifying the number of array
elements, no more than the process variable's maximum native
element count may be requested. The process variable's maximum native
element count is available from ca_element_count() when the channel is
connected. If less elements than the process variable's native element count
are requested the requested values will be fetched beginning at element zero.
By default CA limits the number of elements in an array to be no more than
approximately 16k divided by the size of one element in the array. Starting
with EPICS R3.14 the maximum array size may be configured in the client and
in the server.
Application programs should assume that CA server may be restarted, and
that network connectivity is transient. When you create a CA channel it's
initial connection state will most commonly be disconnected. If the Process
Variable's server is available the library will immediately initiate the
necessary actions to make a connection with it. Otherwise, the client library
will monitor the state of servers on the network and immediately connect or
reconnect with the process variable's server when it becomes available.
Two methods may be used to determine if a channel has connected: the
application program can block in ca_pend_io , or the application program can
install a connection callback handler when it calls ca_create_channel . The ca_pend_io approach is best suited to simple
command line programs with a short runtime duration, and the connection
callback method is best suited to toolkit components with a long runtime
duration. If a connection state change call back function is not
installed when ca_create_channel is called (if a nil function
pointer is supplied) then the application program must wait for
successful status from ca_pend_io
prior to using the channel for the first time. Otherwise, if a connection
state change call back function is supplied, then one of the
arguments to this function distinguishes between connect and disconnect
events, and ca_pend_io will not
block for the channel to connect. The user's connection state change
function will be run immediately from within ca_create_channel if the CA client and
the server are both hosted within the same address space (within the same
process).
Once the channel connects the application program can freely perform IO
operations through the channel, but it should expect that the channel might
disconnect at any time due to network connectivity disruptions or server
restarts.
Starting with EPICS R3.14 the CA client libraries are fully thread safe on
all OS (in past releases the library was thread safe only on vxWorks). When
the client library is initialized the programmer may specify if preemptive
call back is enabled. Preemptive call back is disabled by default. If
preemptive call back is enabled then the user's call back functions might be
called by CA's auxiliary threads when the main initiating channel access
thread is not inside of a function in the channel access client library.
Otherwise, the user's call back functions will be called only when the main
initiating channel access thread is executing inside of the CA client
library. When the CA client library invokes a user's call back function
it will always wait for the current callback to complete prior to executing
another call back function.
To set up a traditional single threaded client you will need code like
this (see ca_context_create and CA Client Contexts and Application Specific Auxiliary
Threads) .
SEVCHK ( ca_context_create(ca_disable_preemptive_callback ),
"application pdq calling ca_context_create" );
To set up a preemptive callback enabled CA client context you will need
code like this (see ca_context_createand CA Client Contexts and Application Specific Auxiliary
Threads) .
SEVCHK ( ca_context_create(ca_enable_preemptive_callback ),
It may be necessary for several CA client side tools running in the same
address space (process) to be independent of each other. For example, the
database CA links and the sequencer are designed to not use the same CA
client library threads, network circuits, and data structures. Each thread
that calls ca_context_create() for the first
time either directly, or implicitly when calling a CA routine for the first
time, creates a CA client library context. A CA client library context
contains all of the threads, network circuits, and data structures required
to connect and communicate with the channels that a CA client application has
created. The priority of auxiliary threads spawned by the CA client library
are at fixed offsets from the priority of the thread that called ca_context_create(). An application specific
auxiliary thread can join a CA context by calling ca_attach_context() using the CA context
identifier that was returned from ca_current_context() when it was called by the
thread that called ca_context_create(). A CA
client library context can be shut down and cleaned up, after destroying any
channels or application specific threads that are attached to it, by calling
ca_context_destroy().
If preemptive call back is not enabled, then for proper operation CA must
periodically be polled to take care of background activity. This requires
that your application must either wait in one of ca_pend_event(),
ca_pend_io(), or ca_sg_block() or alternatively it must call ca_poll() at
least every 100 milli-seconds. In single threaded applications a file
descriptor manager like Xt or the interface described in fdManager.h can be
used to monitor both mouse clicks and also CA's file descriptors so that
ca_poll() can be called immediately when CA server messages arrives over the
network.
With the embryonic releases of EPICS it was a common practice to examine a
channel's connection state, its native type, and its native element count by
directly accessing fields in a structure using a pointer stored in type
chid . Likewise, a user private pointer in the per channel
structure was also commonly set by directly accessing fields in the channel
structure. A number of difficulties arise from this practice, which has long
since been deprecated. For example, prior to release 3.13 it was recognized
that transient changes in certain private fields in the per channel structure
would make it difficult to reliably test the channels connection state using
these private fields directly. Therefore, in release 3.13 the names of
certain fields were changed to discourage this practice. Starting with
release 3.14 codes written this way will not compile. Codes intending to
maintain the highest degree of portability over a wide range of EPICS
versions should be especially careful. For example you should replace all
instances off channel_id->count with
ca_element_count(channel_id) . This approach should be reliable
on all versions of EPICS in use today. The construct ca_puser(chid) =
xxxx is particularly problematic. The best mechanisms for setting the
per channel private pointer will be to pass the user private pointer in when
creating the channel. This approach is implemented on all versions.
Otherwise, you can also use ca_set_puser(CHID,PUSER) , but this
function is available only after the first official (post beta) release of
EPICS 3.13.
Function Call Reference
#include <cadef.h>
enum ca_preemptive_callback_select
{ ca_disable_preemptive_callback, ca_enable_preemptive_callback };
int ca_context_create ( enum ca_preemptive_callback_select SELECT );
Description
This function should be called once prior to making any of the other
channel access calls.
If ca_disable_preemptive_callback is specified then
additional threads are not allowed to join the CA context using
ca_context_attach() because allowing other threads to join implies that CA
callbacks will be called preemptively from more than one thread.
Arguments
SELECT
- Specifies if preemptive callback is allowed. If it is allowed your
callbacks might be called when the thread that calls this routine is
not executing in the CA client library. Programmers who are unfamiliar
with mutual exclusion locking in a multi-threaded environment should
specify
ca_disable_preemptive_callback . If
ca_enable_preemptive_callback is specified then CA client background
activities, such as connection management, will proceed even if the
thread that calls this routine is not executing in the CA client
library.
Returns
ECA_NORMAL - Normal successful completion
ECA_ALLOCMEM - Failed, unable to allocate space in pool
See Also
#include <cadef.h>
void ca_context_destroy();
Description
Shut down a channel access client context and free any resources
allocated. On most operating systems this is performed automatically at
process exit.
Returns
See Also
ca_context_create()
#include <cadef.h>
typedef void ( *pCallBack ) (
struct connection_handler_args );
int ca_create_channel
const char *PROCESS_VARIABLE_NAME,
caCh *USERFUNC,
void *PUSER,
capri priority,
chid *PCHID
Description
This function creates a CA channel. The CA client library will attempt to
establish and maintain a virtual circuit between the caller's application and
a named process variable in a CA server. Each call to ca_create_channel
allocates resources in the CA client library and potentially also a CA
server. The function ca_clear_channel() is used to release these resources.
If successful, the routine writes a channel identifier into the user's
variable of type "chid". This identifier can be used with any channel access
call that operates on a channel.
The circuit may be initially connected or disconnected depending on the
state of the network and the location of the channel. A channel will
only enter a connected state after server's address is determined,
and only if channel access successfully establishes a virtual circuit through
the network to the server. Channel access routines that send a request to a
server will return ECA_DISCONNCHID if the channel is currently
disconnected.
There are two ways to obtain asynchronous notification when a channel
enters a connected state.
- The first and simplest method requires that you call ca_pend_io(), and
wait for successful completion, prior to using a channel that was created
specifying a nil connection call back function pointer.
- The second method requires that you register a connection handler by
supplying a valid connection callback function pointer. This connection
handler is called whenever the connection state of the channel changes.
If you have installed a connection handler then ca_pend_io() will
not block waiting for the channel to enter a connected
state.
The function ca_state(CHID) can be used to test the connection state of a
channel. Valid connections may be isolated from invalid ones with this
function if ca_pend_io() times out.
Due to the inherently transient nature of network connections the order of
connection call backs relative to the order that ca_create_channel() calls
are made by the application can't be guaranteed, and application programs may
need to be prepared for a connected channel to enter a disconnected state at
any time.
Example
See caExample.c in the example application created by makeBaseApp.pl.
Arguments
- A nil terminated process variable name string. EPICS process control
function block database variable names are of the form "<record
name>.<field name>". If the field name and the period
separator are omitted then the "VAL" field is implicit. For
example "RFHV01" and "RFHV01.VAL" reference the same EPICS process
control function block database variable.
USERFUNC
- Optional address of the user's call back function to be run when the
connection state changes. Casual users of channel access may decide to
set this field to nil or 0 if they do not need to have a call back
function run in response to each connection state change event.
The following structure is passed by value to the user's
connection connection callback function. The op field will
be set by the CA client library to CA_OP_CONN_UP when the
channel connects, and to CA_OP_CONN_DOWN when the channel
disconnects. See ca_puser if the
PUSER argument is required in your callback
handler.
struct ca_connection_handler_args {
long op; /* one of CA_OP_CONN_UP or CA_OP_CONN_DOWN */
PUSER
- The value of this void pointer argument is retained in
storage associated with the specified channel. See the MACROS
manual page for reading and writing this field. Casual users of channel
access may wish to set this field to nil or 0.
PRIORITY
- The priority level for dispatch within the server or network with 0
specifying the lowest dispatch priority and 99 the highest. This
parameter currently does not impact dispatch priorities within the
client, but this might change in the future. The abstract priority
range specified is mapped into an operating system specific range of
priorities within the server. This parameter is ignored if the server
is running on a network or operating system that does not have native
support for prioritized delivery or execution respectively. Specifying
many different priorities within the same program can increase resource
consumption in the client and the server because an independent virtual
circuit, and associated data structures, is created for each priority
that is used on a particular server.
PCHID
- The user supplied channel identifier storage is overwritten with a
channel identifier if this routine is successful.
Returns
ECA_BADTYPE - Invalid DBR_XXXX type
ECA_STRTOBIG - Unusually large string
ECA_ALLOCMEM - Unable to allocate memory
ca_clear_channel()
#include <cadef.h>
int ca_clear_channel (evid CHID);
Description
Shutdown and reclaim resources associated with a channel created by
ca_create_channel().
All remote operation requests such as the above are accumulated (buffered)
ca_pend_event, or ca_sg_pend are called. This allows several requests to be
efficiently sent over the network in one message.
Clearing a channel does not cause its disconnect handler to be called, but
clearing a channel does shutdown and reclaim any channel state change event
subscriptions (monitors) registered with the channel.
Arguments
CHID
- Identifies the channel to delete.
Returns
ECA_BADCHID - Corrupted CHID
#include <cadef.h>
int ca_put ( chtype TYPE,
chid CHID, void *PVALUE );
int ca_array_put ( chtype TYPE,
unsigned long COUNT,
chid CHID, const void *PVALUE);
typedef void ( *pCallBack ) (struct event_handler_args );
int ca_put_callback ( chtype TYPE,
chid CHID, const void *PVALUE,
pCallBack PFUNC, void *USERARG );
int ca_array_put_callback ( chtype TYPE,
Description
Write a scalar or array value to a process variable.
When ca_array_put or ca_put are invoked the client will receive no
response unless the request can not be fulfilled in the server. If
unsuccessful an exception handler is run on the client side. If a connection
is lost and then resumed outstanding ca_array_put or ca_put
requests are not automatically reissued following reconnect, and no
additional notification are provided to the user for each put request.
When ca_array_put_callback are invoked the user supplied asynchronous call
back is called only after the initiated write operation and all actions
resulting from the initiating write operation complete. If unsuccessful
the call back function is invoked indicating bad status. If the channel
disconnects before a put callback request can be completed, then the client's
call back function is called with bad status, but this does not guarantee
that the server did not receive and process the request before the
disconnect.
All of these functions return ECA_DISCONN if the channel is currently
disconnected.
All put requests are accumulated (buffered) and not forwarded to the IOC
until one of ca_flush_io, ca_pend_io, ca_pend_event, or ca_sg_pend are
called. This allows several requests to be efficiently combined into one
message.
Arguments
TYPE
- The external type of the supplied value to be written. Conversion
will occur if this does not match the native type. Specify one from the
set of DBR_XXXX in db_access.h
COUNT
- Element count to be written to the specified channel. This must match
the array pointed to by PVALUE.
CHID
- Channel identifier
PVALUE
- Pointer to a value or array of values provided by the application to
be written to the channel.
PFUNC
- address of user supplied callback function
to be run when the requested operation completes
USERARG
- pointer sized variable retained and then passed back to user supplied
function above
Returns
ECA_BADCOUNT - Requested count larger than native element count
ECA_STRTOBIG - Unusually large string supplied
ECA_NOWTACCESS - Write access denied
ECA_DISCONN - Channel is disconnected
See Also
ca_flush_io()
ca_pend_event()
ca_get()
#include <cadef.h>
int ca_get ( chtype TYPE,
int ca_array_get ( chtype TYPE, unsigned long COUNT,
int ca_get_callback ( chtype TYPE,
chid CHID, pCallBack USERFUNC, void *USERARG);
int ca_array_get_callback ( chtype TYPE, unsigned long COUNT,
chid CHID,
pCallBack USERFUNC, void *USERARG );
Description
Read a scalar or array value from a process variable.
When ca_get or ca_array_get are invoked the returned channel value cant be
assumed to be stable in the application supplied buffer until after
ECA_NORMAL is returned from ca_pend_io. If a connection is lost outstanding
get requests are not automatically reissued following reconnect.
When ca_get_callback or ca_array_get_callback are invoked a value is read
from the channel and then the user's callback is invoked with a pointer
to the retrieved value. Note that ca_pend_io will not block for the delivery
of values requested by ca_get_callback. If the channel disconnects before a
get callback request can be completed, then the clients call back function is
called with bad status.
disconnected.
All get requests are accumulated (buffered) and not forwarded to the IOC
called. This allows several requests to be efficiently sent over the network
in one message.
Example
Arguments
TYPE
- The external type of the user variable to return the value into.
Conversion will occur if this does not match the native type. Specify
one from the set of DBR_XXXX in db_access.h
COUNT
- Element count to be read from the specified channel. Must match the
CHID
PVALUE
- Pointer to an application supplied buffer where the current value of
the channel is to be written.
USERFUNC
- Address of user supplied callback function to be
run when the requested operation completes.
USERARG
- Pointer sized variable retained and then passed back to user supplied
call back function above.
Returns
ECA_GETFAIL - A local database get failed
ECA_NORDACCESS - Read access denied
See Also
ca_pend_io()
ca_pend_event()
ca_create_subscription()
#include <cadef.h>
int ca_create_subscription ( chtype TYPE,
unsigned long COUNT, chid CHID,
unsigned long MASK, pCallBack USERFUNC, void *USERARG,
evid *PEVID );
Description
Register a state change subscription and specify a call back function to
be invoked whenever the process variable undergoes significant
state changes. A significant change can be a change in the process variable's
value, alarm status, or alarm severity. In the process control function block
database the deadband field determines the magnitude of a significant change
for for the process variable's value. Each call to this function consumes
resources in the client library and potentially a CA server until one of
ca_clear_channel or ca_clear_event is called.
Subscriptions may be installed or canceled against both
connected and disconnected channels. The specified USERFUNC is called once
immediately after the subscription is installed with the process variable's
current state if the process variable is connected. Otherwise, the specified
USERFUNC is called immediately after establishing a connection (or
reconnection) with the process variable. The specified USERFUNC is called
immediately with the process variable's current state from within
ca_add_event() if the client and the process variable share the same address
space.
If a subscription is installed on a channel in a disconnected state
then the requested count will be set to the native maximum element count of
the channel if the requested count is larger.
All subscription requests such as the above are accumulated (buffered) and
not forwarded to the IOC until one of ca_flush_io, ca_pend_io, ca_pend_event,
or ca_sg_pend are called. This allows several requests to be efficiently sent
If at any time after subscribing, read access to the specified process
variable is lost, then the call back will be invoked immediately indicating
that read access was lost via the status argument. When read access is
restored normal event processing will resume starting always with at
least one update indicating the current state of the channel.
A better name for this function might have been ca_subscribe.
Example
See caMonitor.c in the example application created by makeBaseApp.pl.
Arguments
TYPE
- The type of value presented to the call back funstion. Conversion
will occur if it does not match native type. Specify one from the set
COUNT
- The element count to be read from the specified channel. A count of
zero specifies the native elemnt count.
CHID
- channel identifier
USRERFUNC
- The address of user supplied
callback function to be invoked with each subscription
update.
USERARG
- pointer sized variable retained and passed back to user callback
function
RESERVED
- Reserved for future use. Specify 0.0 to remain upwardly
compatible.
PEVID
- This is a pointer to user supplied event id which is overwritten if
successful. This event id can later be used to clear a specific
event. This option may may be omitted by passing a nil
pointer.
MASK
- A mask with bits set for each of the event trigger types requested.
The event trigger mask must be a logical or of one or more of the
following constants.
- DBE_VALUE - Trigger events when the channel value exceeds the
monitor dead band
- DBE_LOG - Trigger events when the channel value exceeds the
archival dead band
- DBE_ALARM - Trigger events when the channel alarm state
changes.
For functions above that do not include a trigger specification,
events will be triggered when there are significant changes in the
channel's value or when there are changes in the channel's alarm state.
This is the same as "DBE_VALUE | DBE_ALARM."
Returns
ECA_ADDFAIL - A local database event add failed
See Also
ca_pend_event()
ca_flush_io()
ca_clear_subscription()
#include <cadef.h>
int ca_clear_subscription ( evid EVID );
Description
Cancel a subscription.
All ca_clear_event() requests such as the above are accumulated (buffered)
and not forwarded to the server until one of ca_flush_io, ca_pend_io,
efficiently sent together in one message.
Arguments
- EVID
- event id returned by ca_add_event()
Returns
ECA_BADCHID - Corrupted CHID SEE ALSO ca_add_event()
#include <cadef.h>
int ca_pend_io ( double TIMEOUT );
Description
This function flushes the send buffer and then blocks until outstanding ca_get requests complete, and until channels created
specifying nill connection handler function pointers connect for the first
time.
- If ECA_NORMAL is returned then it can be safely assumed that all
outstanding ca_get requests have completed
successfully and channels created specifying nill connection handler
function pointers have connected for the first time.
- If ECA_TIMEOUT is returned then it must be assumed for all previous ca_get requests and properly qualified first time
channel connects have failed.
If ECA_TIMEOUT is returned then get requests may be reissued followed by a
subsequent call to ca_pend_io(). Specifically, the function will
block only for outstanding ca_get requests issued,
and also any channels created specifying a nill connection handler function
pointer, after the last call to ca_pend_io() or ca client context creation
whichever is later. Note that ca_create_channel requests generally should not
be reissued for the same process variable unless ca_clear_channel is called first.
If no ca_get or connection state change events are
outstanding then ca_pend_io() will flush the send buffer and return
immediately without processing any outstanding channel access
background activities.
The delay specified to ca_pend_io() should take into account worst case
network delays such as Ethernet collision exponential back off until
retransmission delays which can be quite long on overloaded networks.
Unlike ca_pend_event , this routine will
not process CA's background activities if none of the selected IO requests
are pending.
Arguments
- TIMEOUT
- Specifies the time out interval. A
TIMEOUT interval of
zero specifies forever.
Returns
ECA_TIMEOUT - Selected IO requests didnt complete before specified
timeout
ECA_EVDISALLOW - Function inappropriate for use within an event handler
See Also
ca_get()
ca_create_channel()
ca_test_io()
#include <cadef.h>
int ca_test_io();
Description
This function tests to see if all ca_get
requests are complete and channels created specifying a nill connection
callback function pointer are connected. It will report the status of
outstanding ca_get requests issued, and channels
created specifying a nill connection callback function pointer, after the
last call to ca_pend_io() or CA context initialization whichever is
later.
Returns
ECA_IODONE - All IO operations completed
ECA_IOINPROGRESS - IO operations still in progress
See Also
ca_pend_io()
#include <cadef.h>
int ca_pend_event ( double TIMEOUT );
int ca_poll ();
Description
When ca_pend_event is invoked the send buffer is flushed and CA background
activity is processed for TIMEOUT seconds.
When ca_poll is invoked the send buffer is flushed and any outstanding CA
background activity is processed.
This routine will not return before the specified time-out
expires and all unfinished channel access labor has been processed, and
unlike ca_pend_io it does not
indicate anything about the status of pending IO requests when it
returns ECA_NORMAL.
See also Thread Safety and Preemptive Callback to User
Code.
Arguments
TIMEOUT
- The duration to block in this routine in seconds. A timeout of zero
seconds blocks forever.
Returns
ECA_TIMEOUT - The operation timed out
ECA_EVDISALLOW - Function inappropriate for use within a call back
handler
#include <cadef.h>
int ca_flush_io();
Description
Flush outstanding IO requests to the server. This routine might
be useful to users who need to flush requests prior
to performing client side labor in parallel with labor performed in the
server.
Outstanding requests are also sent whenever the buffer which holds them
becomes full.
Returns
#include <cadef.h>
int ca_signal ( long CA_STATUS, const char * CONTEXT_STRING );
void SEVCHK( CA_STATUS, CONTEXT_STRING );
Description
Provide the error message character string associated with the supplied
channel access error code and the supplied error context to diagnostics. If
the error code indicates an unsuccessful operation a stack dump is printed,
if this capability is available on the local operating system, and execution
is terminated.
SEVCHK is a macro envelope around ca_signal which only calls ca_signal()
if the supplied error code indicates an unsuccessful operation. SEVCHK is the
recommended error handler for simple applications which do not wish to write
code testing the status returned from each channel access call.
Examples
status = ca_context_create (...);
SEVCHK ( status, "Unable to create a CA client context" );
If the application only wishes to print the message associated with an
error code or test the severity of an error there are also functions provided
for this purpose.
Arguments
CA_STATUS
- The status (error code) returned from a channel access function.
CONTEXT_STRING
- A null terminated character string to supply as error context to
diagnostics.
Returns
#include <cadef.h>
typedef void (*pCallback) ( struct exception_handler_args HANDLERARGS );
int ca_add_exception_event ( pCallback USERFUNC, void *USERARG );
Description
Replace the currently installed CA context global exception handler call
back.
When an error occurs in the server asynchronous to the clients thread then
information about this type of error is passed from the server to the client
in an exception message. When the client receives this exception message
an exception handler callback is called.The default exception handler prints
a diagnostic message on the client's standard out and terminates
execution if the error condition is severe.
Note that certain fields in "struct exception_handler_args" are not
applicable in the context of some error messages. For instance, a failed get
will supply the address in the client task where the returned value was
requested to be written. For other failed operations the value of the addr
field should not be used.
Arguments
USERFUNC
- Address of user callback function to be executed when an exceptions
occur. Passing a nil value causes the default exception handler to be
reinstalled. The following structure is passed by value to the user's
callback function. Currently, the
op field can be one of
CA_OP_GET, CA_OP_PUT, CA_OP_CREATE_CHANNEL, CA_OP_ADD_EVENT,
CA_OP_CLEAR_EVENT, or CA_OP_OTHER.
struct exception_handler_args {
void *usr; /* user argument supplied when installed */
chanId chid; /* channel id (may be nill) */
long type; /* type requested */
long count; /* count requested */
void *addr; /* user's address to write results of CA_OP_GET */
long stat; /* channel access ECA_XXXX status code */
long op; /* CA_OP_GET, CA_OP_PUT, ..., CA_OP_OTHER */
const char *ctx; /* a character string containing context info */
sonst char *pFile; /* source file name (may be NULL) */
unsigned lineNo; /* source file line number (may be zero) */
USERARG
- pointer sized variable retained and passed back to user function
above
Example
void ca_exception_handler (
struct exception_handler_args args)
char buf[512];
char *pName;
if ( args.chid ) {
pName = ca_name ( args.chid );
else{
pName = "?";
sprintf ( buf,
"%s - with request chan=%s op=%d data type=%s count=%d",
args.ctx, pName, args.op, dbr_type_to_text ( args.type ), args.count );
ca_signal ( args.stat, buf );
ca_add_exception_event ( ca_exception_handler , 0 );
Returns
#include <cadef.h>
typedef int caPrintfFunc ( const char *pFromat, va_list args );
int ca_replace_printf_handler ( caPrintfFunc *PFUNC );
Description
Replace the default handler for formatted diagnostic message output. The
default handler uses fprintf to send messages to 'stderr'.
Arguments
PFUNC
- The address of a user supplied call back handler to be invoked when
CA prints diagnostic messages. Installing a nil pointer will cause the
default call back handler to be reinstalled.
Examples
int my_printf ( char *pformat, va_list args ) {
int status;
status = vfprintf( stderr, pformat, args);
return status;
status = ca_replace_printf_handler ( my_printf );
SEVCHK ( status, "failed to install my printf handler" );
Returns
#include <cadef.h>
typedef void ( *pCallBack )( struct access_rights_handler_args );
int ca_replace ( chid CHAN, pCallBack PFUNC );
Description
Install or replace the access rights state change callback handler for the
specified channel.
The callback handler is called in the following situations.
- whenever CA connects the channel immediately before the channel's
connection handler is called
- whenever CA disconnects the channel immediately after the channel's
disconnect call back is called
- once immediately after installation if the channel is connected.
- whenever the access rights state of a connected channel changes
When a channel is created no access rights handler is installed.
Arguments
CHAN
- The channel identifier.
PFUNC
- Address of user supplied call back function. A nil pointer uninstalls
the current handler. The following arguments are passed by
value to the supplied callback handler.
typedef struct ca_access_rights {
unsigned read_access:1;
unsigned write_access:1;
} caar;
/* arguments passed to user access rights handlers */
struct access_rights_handler_args {
caar ar; /* new access rights state */
Returns
See Also
ca_modify_user_name()
ca_modify_host_name()
#include <cadef.h>
chtype ca_field_type ( CHID );
Description
Return the native type in the server of the process variable.
Arguments
CHID
Returns
TYPE
- The data type code will be a member of the set of DBF_XXXX
in db_access.h. The constant TYPENOTCONN is returned if the channel is
disconnected.
ca_element_count()
#include <cadef.h>
unsigned ca_element_count ( CHID );
Description
Return the maximum array element count in the server for the
specified IO channel.
Arguments
CHID
Returns
COUNT
- The maximum array element count in the server. An element
count of zero is returned if the channel is disconnected.
#include <cadef.h>
char * ca_name ( CHID );
Description
Return the name provided when the supplied channel id was created.
Arguments
CHID
Returns
PNAME
- The channel name. The string returned is valid as long as the channel
specified exists.
#include <cadef.h>
void ca_set_puser ( chid CHID, void *PUSER );
Description
Set a user private void pointer variable retained with each channel
for use at the users discretion.
Arguments
- CHID
- PUSER
- user private void pointer
#include <cadef.h>
void * ca_puser ( CHID );
Description
Return a user private void pointer variable retained with each channel for
Arguments
CHID
Returns
PUSER
- user private pointer
#include <cadef.h>
enum channel_state {
cs_never_conn, /* valid chid, server not found or unavailable */
cs_prev_conn, /* valid chid, previously connected to server */
cs_conn, /* valid chid, connected to server */
cs_closed }; /* channel deleted by user */
enum channel_state ca_state ( CHID );
Description
Returns an enumerated type indicating the current state of the specified
IO channel.
Arguments
CHID
Returns
STATE
- the connection state
#include <cadef.h>
const char * ca_message ( STATUS );
Description
return a message character string corresponding to a user specified CA
status code.
Arguments
STATUS
- a CA status code
Returns
- STR
ING
- the corresponding error message string
#include <cadef.h>
char * ca_host_name ( CHID );
Description
Return a character string which contains the name of the host to which a
channel is currently connected.
Arguments
CHID
- the channel identifier
Returns
STRING
- The process variable server's host name. If the channel is
disconnected the string "<disconnected>" is returned.
#include <cadef.h>
int ca_read_access ( CHID );
Description
Returns boolean true if the client currently has read access to
the specified channel and boolean false otherwise.
Arguments
CHID
Returns
STRING
- boolean true if the client currently has read access to the
#include <cadef.h>
int ca_write_access ( CHID );
Description
Returns boolean true if the client currently has write
access to the specified channel and boolean false otherwise.
Arguments
CHID
Returns
STRING
- boolean true if the client currently has write access to the
#include <db_access.h>
extern unsigned dbr_size[/*TYPE*/];
Description
An array that returns the size in bytes for a DBR_XXXX type.
Arguments
TYPE
- The data type code. A member of the set of DBF_XXXX in
db_access.h.
Returns
SIZE
- the size in bytes of the specified type
unsigned dbr_size_n ( TYPE, COUNT );
Description
Returns the size in bytes for a DBR_XXXX type with COUNT
elements. If the DBR type is a structure then the value field is the
last field in the structure. If COUNT is greater than one then COUNT-1
elements are appended to the end of the structure so that they can be
addressed as an array through a pointer to the value field.
Arguments
TYPE
- The data type
COUNT
- The element count
Returns
SIZE
- the size in bytes of the specified type with the specified number of
elements
extern unsigned dbr_value_size[/* TYPE */];
Description
The array dbr_value_size[TYPE] returns the size in bytes for the value
stored in a DBR_XXXX type. If the type is a structure the size of the value
field is returned otherwise the size of the type is returned.
Arguments
TYPE
db_access.h.
Returns
SIZE
- the size in bytes of the value field if the type is a structure and
otherwise the size in bytes of the type
const char * dbr_type_text ( chtype TYPE );
Description
Returns a constant null terminated string corresponding to the specified
dbr type.
Arguments
TYPE
- The data type code. A member of the set of DBR_XXXX in
db_access.h.
Returns
STRING
- The const string corresponding to the DBR_XXX type.
#include <cadef.h>
Description
void ca_test_event ( struct event_handler_args );
A built-in subscription update call back handler for debugging purposes
that prints diagnostics to standard out.
Examples
void ca_test_event ();
status = ca_add_event ( type, chid, ca_test_event, NULL, NULL );
SEVCHK ( status, .... );
See Also
ca_add_event()
#include <cadef.h>
int ca_sg_create ( CA_SYNC_GID *PGID );
Description
Create a synchronous group and return an identifier for it.
A synchronous group can be used to guarantee that a set of channel access
requests have completed. Once a synchronous group has been created then
channel access get and put requests may be issued within it using ca_sg_get()
and ca_sg_put() respectively. The routines ca_sg_block() and ca_sg_test() can
be used to block for and test for completion respectively. The routine
ca_sg_reset() is used to discard knowledge of old requests which have timed
out and in all likelihood will never be satisfied.
Any number of asynchronous groups can have application requested
operations outstanding within them at any given time.
Arguments
PGID
- Pointer to a user supplied CA_SYNC_GID.
Examples
CA_SYNC_GID gid;
status = ca_sg_create ( &gid );
SEVCHK ( status, Sync group create failed );
Returns
ECA_ALLOCMEM - Failed, unable to allocate memory
See Also
ca_sg_delete()
ca_sg_block()
ca_sg_test()
ca_sg_reset()
ca_sg_put()
ca_sg_get()
#include <cadef.h>
int ca_sg_delete ( CA_SYNC_GID GID );
Description
Deletes a synchronous group.
Arguments
- GID
- Identifier of the synchronous group to be deleted.
Examples
CA_SYNC_GID gid;
status = ca_sg_delete ( gid );
SEVCHK ( status, Sync group delete failed );
Returns
ECA_BADSYNCGRP - Invalid synchronous group
See Also
ca_sg_create()
#include <cadef.h>
int ca_sg_block ( CA_SYNC_GID GID, double timeout );
Description
Flushes the send buffer and then waits until outstanding requests complete
or the specified time out expires. At this time outstanding requests include
calls to ca_sg_array_get() and calls to ca_sg_array_put(). If ECA_TIMEOUT is
returned then failure must be assumed for all outstanding queries. Operations
can be reissued followed by another ca_sg_block(). This routine will only
block on outstanding queries issued after the last call to ca_sg_block(),
ca_sg_reset(), or ca_sg_create() whichever occurs later in time. If no
queries are outstanding then ca_sg_block() will return immediately without
processing any pending channel access activities.
Values written into your program's variables by a channel access
synchronous group request should not be referenced by your program until
ECA_NORMAL has been received from ca_sg_block(). This routine
will process pending channel access background activity while it is
waiting.
Arguments
- GID
- Identifier of the synchronous group.
Examples
CA_SYNC_GID gid;
status = ca_sg_block(gid);
SEVCHK(status, Sync group block failed);
Returns
See Also
ca_sg_test()
ca_sg_reset()
#include <cadef.h>
int ca_sg_test ( CA_SYNC_GID GID )
Description
Test to see if all requests made within a synchronous group have
completed.
Arguments
GID
Description
completed.
Examples
CA_SYNC_GID gid;
status = ca_sg_test ( gid );
Returns
ECA_IODONE - IO operations completed
ECA_IOINPROGRESS - Some IO operations still in progress
#include <cadef.h>
int ca_sg_reset ( CA_SYNC_GID GID )
Description
Reset the number of outstanding requests within the specified synchronous
group to zero so that ca_sg_test() will return ECA_IODONE and ca_sg_block()
will not block unless additional subsequent requests are made.
Arguments
GID
Examples
CA_SYNC_GID gid;
status = ca_sg_reset(gid);
Returns
#include <cadef.h>
int ca_sg_array_put ( CA_SYNC_GID GID, chtype TYPE,
unsigned long COUNT, chid CHID, void *PVALUE );
Write a value, or array of values, to a channel and increment the
outstanding request count of a synchronous group.
and not forwarded to the server until one of ca_flush_io(), ca_pend_io(),
ca_pend_event(), or ca_sg_pend() are called. This allows several requests to
be efficiently sent in one message.
If a connection is lost and then resumed outstanding puts are not
reissued.
Arguments
GID
- synchronous group identifier
TYPE
- The type of supplied value. Conversion will occur if it does not
match the native type. Specify one from the set of DBR_XXXX in
db_access.h.
COUNT
- element count to be written to the specified channel - must match the
CHID
PVALUE
- A pointer to an application supplied buffer containing the value or
array of values returned
Returns
ECA_PUTFAIL - A local database put failed
See Also
ca_flush_io()
#include <cadef.h>
int ca_sg_array_get ( CA_SYNC_GID GID,
Description
Read a value from a channel and increment the outstanding request count of
The values written into your program's variables by ca_sg_get should not
be referenced by your program until ECA_NORMAL has been received from
ca_sg_block , or until ca_sg_test returns ECA_IODONE.
If a connection is lost and then resumed outstanding gets are not
reissued.
Arguments
GID
TYPE
- External type of returned value. Conversion will occur if this does
not match native type. Specify one from the set of DBR_XXXX in
db_access.h
COUNT
- Element count to be read from the specified channel. It must match
CHID
PVALUE
- Pointer to application supplied buffer that is to contain the value
or array of values to be returned
Returns
See Also
ca_pend_io()
ca_flush_io()
ca_get_callback()
int ca_client_status ( unsigned level );
int ca_context_status ( struct ca_client_context *,
unsigned level );
Description
Prints information about the client context including, at higher interest
levels, status for each channel. Lacking a CA context pointer,
ca_client_status() prints information about the calling threads CA
context.
Arguments
CONTEXT
- A pointer to the CA context to join with.
LEVEL
- The interest level. Increasing level produces increasing detail.
struct ca_client_context * ca_current_context ();
Description
Returns a pointer to the current thread's CA context. If none then nil is
returned.
See Also
ca_attach_context()
int ca_attach_context (struct ca_client_context *CONTEXT);
Description
Become a member of the specified CA context. If
ca_disable_preemptive_callback is specified when
ca_context_create() is called (or if ca_task_initialize() is called) then
additional threads are not allowed to join the CA context because
allowing other threads to join implies that CA callbacks will be called
Arguments
CONTEXT
Returns
ECA_ISATTACHED - already attached to a CA context
See Also
void ca_dump_dbr ( chtype TYPE, unsigned COUNT, const
void * PDBR );
Description
Dumps the specified dbr data type to standard out.
Arguments
TYPE
- The data type (from the DBR_XXX set described in db_access.h).
COUNT
- The array element count
PDBR
- A pointer to data of the specified count and number.
- ECA_NORMAL
- ECA_ALLOCMEM
- Unable to allocate additional dynamic memory
- ECA_TOLARGE
- The requested data transfer is greater than available memory or
EPICS_CA_MAX_ARRAY_BYTES
- ECA_BADTYPE
- The data type specified is invalid
- ECA_BADSTR
- Invalid string
- ECA_BADCHID
- Invalid channel identifier
- ECA_BADCOUNT
- Invalid element count requested
- ECA_PUTFAIL
- Channel write request failed
- ECA_GETFAIL
- Channel read request failed
- ECA_ADDFAIL
- unable to install subscription request
- ECA_TIMEOUT
- User specified timeout on IO operation expired
- ECA_EVDISALLOW
- function called was inappropriate for use within a callback
function
- ECA_IODONE
- IO operations have completed
- ECA_IOINPROGRESS
- IO operations are in progress
- ECA_BADSYNCGRP
- Invalid synchronous group identifier
- ECA_NORDACCESS
- ECA_NOWTACCESS
- ECA_DISCONN
- Virtual circuit disconnect"
- ECA_DBLCHNL
- Identical process variable name on multiple servers
- ECA_EVDISALLOW
- Request inappropriate within subscription (monitor) update
callback
- ECA_BADMONID
- Bad event subscription (monitor) identifier
- ECA_BADMASK
- Invalid event selection mask
- ECA_PUTCBINPROG
- Put callback timed out
- ECA_PUTCBINPROG
- ECA_ANACHRONISM
- Requested feature is no longer supported
- ECA_NOSEARCHADDR
- Empty PV search address list
- ECA_NOCONVERT
- No reasonable data conversion between client and server types
- ECA_BADFUNCPTR
- Invalid function pointer
- ECA_ISATTACHED
- Thread is already attached to a client context
- ECA_UNAVAILINSERV
- Not supported by attached service
- ECA_CHANDESTROY
- User destroyed channel
- ECA_BADPRIORITY
- Invalid channel priority
- ECA_NOTTHREADED
- Preemptive callback not enabled - additional threads may not join
context
- ECA_16KARRAYCLIENT
- Client's protocol revision does not support transfers exceeding 16k
bytes
$Id: CAref.html,v 1.57 2003/05/21 23:17:09 jhill Exp $
