1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: IOC memory leak? Proper shutdown?
To: "'[email protected]'" <[email protected]>
Date: Wed, 23 Apr 2003 13:47:24 -0600
I am a new user of EPICS (3.14.1) on a win32(Win2K) platform.  I have
several client applications developed within the MSVC(6.0) IDE framework
that communicate using a similar framework.  I am in the early stages of
converting these applications to use EPICS Channel Access.  I have also
folded the example IOC program into an MFC application and hope to
incorporate some of the configuration and diagnostic tools that we have.  I
am able to initialize the IOC and access the data using channel access
clients but in the MSVC debugger I get a warning:  "Detected memory leaks!"
that appear to come from the call to iocInit().  Is there a proper way to
release these resources at shutdown.  I would rather not rely on windows for
this task.  Besides the necessary includes, this is the extent of the added
code in this application.
// IOC Initialization
dbLoadDatabase("c:/epics/ioc_test2/example.dbd",0,0);
registerRecordDeviceDriver(pdbbase);
dbLoadRecords("c:/epics/ioc_test2/db/dbExample1.db","user=AdministratorHost"
dbLoadRecords("c:/epics/ioc_test2/db/dbExample2.db","user=AdministratorHost,
no=1,scan=1 second");
no=2,scan=2 second");
no=3,scan=5 second");
dbLoadRecords("c:/epics/ioc_test2/db/dbSubExample.db","user=AdministratorHos
t");
iocInit();
epicsThreadSleep(.2);
I have some additional questions but will limit one subject per message.
Thank you for your time.
Randy Wells
15425, Missile and Flight Systems
Sandia National Labs
Ph:  (505) 284-4849
Fax:  (505)  844-1168
e-mail:  [email protected]
Prev: OWL Newsletter - Training Products Greg Parks
Next: pdbbase usage and scope Wells, Randall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
