Benjamin Franksen wrote:
> PS: I finally understood the S_db_Blocked issue (after reading the code
> in base and then re-reading the doc): S_db_Blocked is only returned if
> an existing put notify block in the target record is the *same* object
> (address comparison) as the one that is now being given as argument.
> Multiple putNotifies to the same target record seem to be no problem at
> all as long as they come from different clients, otherwise they are
> ignored. This is make sense, indeed. The Developer's Guide could be a
> little more clear on this point; it says "If a putNotify is already
> active..." which is of course fine if one already knows what is meant.
Uh-oh. This isn't the way I understood putNotify. It would be a disaster
for one client to initiate a putNotify trace on the same record, or even a
different record in the same lockset, as an ongoing putNotify trace. How
could you ensure that the two execution traces would not interfere with
each other?
Tim Mooney ([email protected]; 630-252-5417)
Advanced Photon Source
APS Operations Division
Beamline Controls & Data Acquisition Group
- RE: recDynLink.c for R3.14.1 ? Feng, Shuchen
- Re: recDynLink.c for R3.14.1 ? Tim Mooney
- Re: recDynLink.c for R3.14.1 ? Kate Feng
- Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
- Re: recDynLink.c for R3.14.1 ? Marty Kraimer
CAMAC problems Hammonds, John P.
<2003>
<2003>
