Benjamin Franksen wrote:
Hi Marty (and all),
one important limitation (at least in 3.13.x) is missing in appDevGuide:
dbNotifyCancel must not be called from interrupt context.
I did and very bad things happened. BTW, i wonder what will happen if
such a record (i.e. one with asynch soft support) is processed as a
result of a ca_put_calback. Hmmm...
Ben
VERY few things can be called from interrupt context.
The Application Developer's Guide says if a routine can get called from
interrupt routines. If it does not say this it should be assumed that the
routine can't be called from interrupt context.
Note that the following can be called from interrupt level
callbackRequest
callbackRequestProcessCallback
scanIorequest
One of these should be all you need. For example callbackRequest can cause a
user supplied routine to be called by a general purpose callback thread.
Marty Kraimer
- Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
- RE: recDynLink.c for R3.14.1 ? Feng, Shuchen
- Re: recDynLink.c for R3.14.1 ? Tim Mooney
- Re: recDynLink.c for R3.14.1 ? Kate Feng
- Re: recDynLink.c for R3.14.1 ? Marty Kraimer
db_parse returned -1 M.C.Shao
<2003>
<2003>
