1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epicsMutexLockWithTimeout not supported in 3.14.1
To: "Allison, Stephanie" <[email protected]>, "'[email protected]'" <[email protected]>
Date: Mon, 14 Apr 2003 11:03:13 -0600
At 10:52 4/14/2003, Allison, Stephanie wrote:
>Hello -
>We use two device/driver support packages here at SSRL that require
>the functionality of epicsMutexLockWithTimeout which is no longer supported
>in 3.14.1.  In ipac, it's only needed by the canRead diagnostic routine so I simply
>used the same logic I found in epics base/src/db/dbLock.c which does a little
>loop with try/wait.   But in ether_ip, this functionality is a key part of the support.
>There was discussion about this in core-talk and a few sentences in the 3.14.1
>release notes, but it's not clear the best way to port from epicsMutexLockWithTimeout
>(or vxWorks semTake with a non-WAIT_FOREVER timeout) to something
>equivalent.
>Any suggestions?  Thank you,
Hello Stephanie:
I'm wondering about a similar issue here and found that
epicsMutex has only lock(), unlock()
while epicsEvent has signal(), wait(), wait(double timeout).
My conclusion was:
use epicsMutex and hang in lock() w/o timeout in cases
where you absolutely need a resource and couldn't proceed
after a timeout, so why bother?
For thread synchronization where a wait(timeout) might well
time out in some cases, but you can print an error message
and do something else for a while, use epicsEvent.
-Kay
Prev: epicsMutexLockWithTimeout not supported in 3.14.1 Allison, Stephanie
Next: RE: epicsMutexLockWithTimeout not supported in 3.14.1 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: epicsMutexLockWithTimeout not supported in 3.14.1 Jeff Hill
Next: Channel Access disconnect/reconnect Nick Rees
