Did you try increasing the number of mbufs for your vxWorks
systems IP kernel?
Jeff
> -----Original Message-----
> From: Erik Johansson [mailto:[email protected]]
> Sent: Thursday, April 10, 2003 1:43 PM
> To: tech-talk (E-mail)
> Subject: EPICS / file load interaction problem
> Hello again -
> A follow-up on my previous posting regarding the problem of
> reading
> NFS-mounted files on an IOC while EPICS is running:
> I thoroughly investigated our network to make sure that there
> were no
> network problems causing the poor file-load performance. I also
> tried
> running my file-load code snippet on other IOCs in our system,
> with no
> change in behavior. Finally, and most interesting, I set up a
> bare-bones IOC
> in our electronics lab and was able to reproduce the problem.
> There are 4
> linked soft records, one of which is scanned at 0.5 seconds.
> After IOC init,
> my file read routine works just fine until I run camonitor on
> one of the
> channels. As soon as camonitor begins, the file load problems
> occur. I don't
> understand the underlying mechanism of monitors, but I am
> hoping that this
> is the key to the file load problems.
> Does anyone understand monitors enough to explain why they
> would interfere
> with the reading of an NFS-mounted file? And, more importantly,
> is there
> anything I can do to fix the problem?
> Any help you can give me is greatly appreciated.
> Erik
> Erik M. Johansson
> Adaptive Optics Software Engineer
> W. M. Keck Observatory
> 65-1120 Mamalahoa Hwy
> Kamuela, HI 96743
> Tel: 808-885-7887
> Fax: 808-885-4464
- EPICS / file load interaction problem Erik Johansson
OSI bumples reboot (R3.14.1) Dylan Maher Loughnan
<2003>
<2003>
