1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS / file load interaction problem
To: "tech-talk (E-mail)" <[email protected]>
Date: Thu, 10 Apr 2003 09:42:39 -1000
Hello again -
 A follow-up on my previous posting regarding the problem of reading
NFS-mounted files on an IOC while EPICS is running:
I thoroughly investigated our network to make sure that there were no
network problems causing the poor file-load performance. I also tried
running my file-load code snippet on other IOCs in our system, with no
change in behavior. Finally, and most interesting, I set up a bare-bones IOC
in our electronics lab and was able to reproduce the problem. There are 4
linked soft records, one of which is scanned at 0.5 seconds. After IOC init,
my file read routine works just fine until I run camonitor on one of the
channels. As soon as camonitor begins, the file load problems occur. I don't
understand the underlying mechanism of monitors, but I am hoping that this
is the key to the file load problems.
Does anyone understand monitors enough to explain why they would interfere
with the reading of an NFS-mounted file? And, more importantly, is there
anything I can do to fix the problem?
Any help you can give me is greatly appreciated.
Erik
Erik M. Johansson
Adaptive Optics Software Engineer
W. M. Keck Observatory
65-1120 Mamalahoa Hwy
Kamuela, HI 96743
Tel: 808-885-7887
Fax: 808-885-4464
RE: EPICS / file load interaction problem Jeff Hill
Prev: MPF release R1-10 Marty Kraimer
Next: RE: EPICS / file load interaction problem Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
