When I first tried to run ca_test after building R3.14.1 on Linux I
received a segmentation fault. After killing caRepeater and running
ca_test again everything worked fine. As I suspected the interaction
with a R3.14 CA client with a R3.13 caRepeater is not optimal. Is this
the expected behaviour? Ca_test from R3.13 does work with the R3.14
caRepeater.
Geoff
- RE: caRepeater R3.13 vs. R3.14 Jeff Hill
Re: stringIn record monitors Brian McAllister
problems switching ioc's ip address Dale L. Brewe
<2003>
Re: stringIn record monitors Andrew Johnson
<2003>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
