1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: vxworks location
To: Geoff Savage <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Tue, 01 Apr 2003 15:42:27 -0600
You should give a fullpath name to VX_DIR in your RELEASE.solaris-sparc
file. The configure/os/CONFIG.Common.vxWorksCommon file contains the
line WIND_BASE=$(VX_DIR).
If you want to set VX_DIR=$(WIND_BASE) in the RELEASE.solaris-sparc file
you must override the WIND_BASE=$(VX_DIR) definition by placing the full
path name definition of WIND_BASE in a config file that is included after
os/CONFIG.Common.vxWorksCommon e.g. os/CONFIG_SITE.Common.vxWorksCommon
Janet
Geoff Savage wrote:
I created a RELEASE.solaris-sparc file to override the VX_DIR location.
VX_DIR = $(WIND_BASE)
Before executing gmake I setup WIND_BASE to point to the base location of the Tornado 2.0.2 installation. Now I execute gmake and get:
gmake[2]: Entering directory `/usr/products/devel/savage/epics/base-3.14.1/config/O.vxWorks-ppc603_long'
.../../configure/RULES_BUILD:294: *** Recursive variable `VX_DIR' references itself (eventually). Stop.
gmake[2]: Leaving directory `/usr/products/devel/savage/epics/base-3.14.1/config/O.vxWorks-ppc603_long'
gmake[1]: *** [install.vxWorks-ppc603_long] Error 2
gmake[1]: Leaving directory `/usr/products/devel/savage/epics/base-3.14.1/config'
gmake: *** [config.install] Error 2
When I use a hard coded directory for VX_DIR as in configure/RELEASE everything compiles as expected.
What did I miss? Thanks
Geoff
vxworks location Geoff Savage
Prev: vxworks location Geoff Savage
Next: stringIn record monitors Bill Cruise
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
