1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: medm unable to contact CA repeater after 50 tries
To: "'M.C.Shao'" <[email protected]>, "'Tech-talk'" <[email protected]>
Date: Wed, 26 Mar 2003 09:50:16 -0700
> The message is:
> Unable to contact CA repeater after 50 tries
> Silence this message by starting a CA repeater daemon
What version of EPICS are you using?
1) In general, to avoid this message make sure that the directory
containing the caRepeater is in your path when running CA client
programs.
2) Verify that there is a CA repeater process running by using
the ps command. If not then run it by hand and verify that it
does not unexpectedly emit a message and quit. Make certain that
both the CA client program and the CA repeater have the same
value in the environment variable EPICS_CA_REPEATER_PORT.
3) Next, use the netstat -a | grep 5065 command to verify that
the repeater daemon is listening on the repeater's port number.
The above port might be different if you have set
EPICS_CA_REPATER_PORT to a non default value.
Jeff
> -----Original Message-----
> From: M.C.Shao [mailto:[email protected]]
> Sent: Wednesday, March 26, 2003 8:46 AM
> To: Tech-talk
> Subject: medm unable to contact CA repeater after 50 tries
> hi, friends,
> when I run medm, it's unable to contact CA repeater.The message
> is:
> After I start a caRepeater mannually, the problem still exists.
> What's wrong?
> btw:I saw this before, and resolved, but unfornately I've
> forgotten what I did.
> best regards,
> Shao Mingchao
> Engineering Physics Department
> Tsinghua University
> Beijing,100084,China
> Tel:86-10-62784552
Re: medm unable to contact CA repeater after 50 tries M.C.Shao
Prev: medm unable to contact CA repeater after 50 tries M.C.Shao
Next: Re: medm unable to contact CA repeater after 50 tries M.C.Shao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
