Lifang Zheng wrote:
> Dear all,
> Could somebody explain about the restriction of naming channels from
> the history of EPICS developing? I learned from APS web site, the total
> length of channel name should be less than 28 characters. Do EPICS base
> & CA library support different length of channel names? Is there any
> modification in EPICS new versions for the limits?
> Is there any limit in the character length between two delimiters(:)
> among channel name?
> Any information is welcome.
> Regards,
> Lifang
For R3.13 the name must be <= 28 characters.
For R3.14 the name must be <= 60 characters
I believe that CA has no limits on channel names. Jeff can verify.
Warning:
If you use 3.14 and have channel names longer than 28 characters some Channel
Access clients may break. Also you may not be able to dynamically modify soft links.
Marty Kraimer
- RE: the length of channel name Jeff Hill
- the length of channel name Lifang Zheng
Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
<2003>
<2003>
