1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Long expressions using MAX and MIN in CALC fields
To: Tim Mooney <[email protected]>, TECHTALK <[email protected]>
Date: Wed, 19 Mar 2003 10:46:27 +0100
Tim Mooney wrote:
Russell,
I have new versions of postfix and calcPerform, which implement the
<? and >? operators, and which allow two or more (up to 20) arguments
to min() and max() functions.  I've tested only under R3.13.5 on an
MV162.  Here's the tar file:
http://www.aps.anl.gov/xfd/SoftDist/swBCDA/postfix_R3.13.5.tar.gz
There seems to be a problem with the calcCheck() function.
When I try to use the ? operator without : (that is allowed), I get this error:
Illegal field value PV: ZIMOCH:calc calc: special: Illegal CALC field
I tried "A>B?C"
Using ?: works fine
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
Long expressions using MAX and MIN in CALC fields Redman, Russell O.
Prev: the length of channel name Lifang Zheng
Next: Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
