1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PC-104/Plus as IOC's
To: "Billy R. Adams" <[email protected]>
Cc: [email protected]
Date: Tue, 18 Mar 2003 16:30:49 -0800
tri-m systems ( http://www.tri-m.com/ ) make a pc104+ card based
on the zfx86 chip from zfmicro. We are using it in situations
where we only require a network for device support.
A bsp for vxWorks 5.4 is available from zfmicro but is incompatible
with vxWorks 5.5. We are currently running with EPICS R3.13.5
graham
+---------------------------------------------------------------------+ |Graham Waters, Control System Eng phone: (604)-222-1047 | |TRIUMF --- University of B.C, Fax: (604)-222-7307 | |Vancouver, BC, Canada e-mail: [email protected] | | | |http://isacwserv.triumf.ca/homepage/graham01.html | +---------------------------------------------------------------------+ For every expert there is an equal and opposite expert - Arthur C Clark
Billy R. Adams wrote:
      Is anyone using PC-104 or PC-104+ cards as IOC's?
Do you recommend them?  Problems?  Advantages?  Sources?
Any other info on them that you can offer?
      We are considering using these cards to replace some
KineticSystems Corporation Model VXI 195-21 IOC's as part
of EPICS systems upgrades in the Research Facilities Branch
at NASA-Langley Research Center.  We would like to use the
PC-104+ to get the PCI bus, but perhaps the PC-104 could be
used instead.
Billy Adams    <mailto:[email protected]>
PC-104/Plus as IOC's Billy R. Adams
Prev: RE: PC-104/Plus as IOC's / PC PCI bus IOC David Purcell
Next: how can i get sch2db? zhaozhuo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: PC-104/Plus as IOC's Eric Williams
Next: Re: PC-104/Plus as IOC's Billy R. Adams
