1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PC-104/Plus as IOC's
To: "Billy R. Adams" <[email protected]>
Cc: [email protected]
Date: Mon, 17 Mar 2003 13:53:40 -0600
Billy R. Adams wrote:
Is anyone using PC-104 or PC-104+ cards as IOC's? Do you recommend them? Problems? Advantages? Sources? Any other info on them that you can offer?
      We are considering using these cards to replace some
KineticSystems Corporation Model VXI 195-21 IOC's as part
of EPICS systems upgrades in the Research Facilities Branch
at NASA-Langley Research Center.  We would like to use the
PC-104+ to get the PCI bus, but perhaps the PC-104 could be
used instead.
I used a VersaLogic Bobcat (PC-104+) as a simple R3.14 IOC running RTEMS. No major problems with the application. The board looks pretty much like a generic PC from the software's point of view.
PRO: Cheap, small
CON: If you need very many I/O cards you've got a maintenance headache -- to replace a bad board you've got to remove every card above it first.
Eric Norum                                 [email protected]
Advanced Photon Source                     Phone: (630) 252-4793
Argonne National Laboratory
PC-104/Plus as IOC's Billy R. Adams
Prev: PC-104/Plus as IOC's Billy R. Adams
Next: [Fwd: Re: PC-104/Plus as IOC's] Billy R. Adams
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: PC-104/Plus as IOC's Eric Williams
