1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: compile problem medmCartesianPlot
To: Burkhard Kolb <[email protected]>
Cc: [email protected]
Date: Fri, 14 Mar 2003 10:49:20 -0600
Burkhard Kolb wrote:
I successfully installed base R3.14.1 on Mac OS X.
When trying to build medm I get the following compiler error:
make -C O.darwin-ppc -f ../Makefile.Host T_A=darwin-ppc BUILD_TYPE=Host install
gcc -ansi -pedantic -D_POSIX_C_SOURCE=199506L -g -Wall -DFLDNAME_SZ=4 -DSCIPLOT -DMOTIF -DEDITRES -fPIC -D_REENTRANT -DUNIX -no-cpp-precomp -I. -I.. -I../../printUtils -I../../xc -I/sw/Xm/include -I/usr/X11R6/include/X11 -I../../../../include/os/Darwin -I../../../../include -I/Volumes/user/epics/base/include/os/Darwin -I/Volumes/user/epics/base/include -I/sw/include -I/usr/X11R6/include -c ../medmCartesianPlot.c
...../medmCartesianPlot.c:44: parse error before "sizeof"
make[1]: *** [medmCartesianPlot.o] Error 1
make: *** [install.darwin-ppc] Error 2
Any clue?
What version of the MEDM source do you have? This sounds like a problem with isnan that was fixed last September.
Does the code around line 44 on your version look like the following? On Mac OS X it's important to have the
extern int isnan(double);
before the
#include <math.h>
#ifdef WIN32
#include <float.h>
#define isnan(a) _isnan(a) /* For some reason MS has leading _ */
#else
extern int isnan(double); /* In case it's not in math.h as it should be */
#include <math.h> /* Must follow extern statement in case isnan is a macro */
#endif /* WIN32 */
#define NAN_SUBSTITUTE 0.0
#define SAFEFLOAT(x) (safeFloat(x))
#else
#define SAFEFLOAT(x) ((float)(x))
#endif /* End #ifdef CHECK_NAN */
Eric Norum                                 [email protected]
Advanced Photon Source                     Phone: (630) 252-4793
Argonne National Laboratory
Re: compile problem medmCartesianPlot Burkhard Kolb
Prev: compile problem medmCartesianPlot Burkhard Kolb
Next: Re: compile problem medmCartesianPlot Burkhard Kolb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
