Do you know where i can find some help : reference and examples on EZCA clients. Have you seen http://www.aps.anl.gov/epics/extensions/index.php In particular the section on "CA Interfaces to other tools and languages" provides some links to ezca documentation. can i use callback function with it? Since it provides ezcaPvToChid the answer is yes.But then you are back to standard CA API calls. The main reason ezca was developed was because some users said that they did not want to program via callbacks. Thus if an application wants callbacks it may be better to just use the CA API. Marty Kraimer
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
