1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Serial driver for Linux
To: GOURNAY Jean-François DAPNIA <[email protected]>
Cc: <[email protected]>
Date: Tue, 25 Feb 2003 10:19:44 -0700
I do not have a drvSerial / drvASCII for Linux.
However, I wonder if you need to use the FieldPoint I/O
System from National Instrument???
I have used the FieldPoint I/O in combination with LabVIEW using
Kay Kasemir's ActiveX CA Server for EPICS.
>From my experience FieldPoint is not bad but there are other
distributed I/O systems on the market that are cheaper, better
configurable and have a wider range of I/O modules to choose from.
In particular if you are not interested in using LabVIEW as
your primary software application platform.
The Controls and Automation Group here in Los Alamos has
recently tested for the SNS Accelerator in Oakridge TN, USA the
I/O System from Beckhoff Automation http://www.beckhoff.com/.
After reviewing the test results we decided to use for our
applications the Fieldbus system with the EthernetTCP/IP module
that supports MobusTCP
http://www.beckhoff.com/english/busterm/Bk9000.htm
Check out the line of Bus Terminals that they have
http://www.beckhoff.com/english/busterm/default.htm.
Richard Dabney ([email protected]) wrote the EPICS driver.
Just a thought. Let me know if you need more info.
Regards
Martin
                 (o -)
--------------oOO-(_)-OOo-------------------------------------------
 Martin Pieck              |     *           *               *   \\
 MS H820, SNS-4, LANL      | *        *        /\   *            =))
 Los Alamos, NM 87545, USA |   * /\        *  /  \    /\  /\     //
                           |/\  /  \/\      _/    \/\/  \/  \ *
 (505) 665-0086 office     |  \/      \  /\/              o  \   *
 (505) 665-5107 fax        |           \/     __o       </\_  \   /\
                           |     /\o_         \<      __/\     \_/
 (505) 661-7270 home       |  ^^^^^^^^^^   (()) (())    /
____________________________________________________________________
-----Original Message-----
From: GOURNAY Jean-François DAPNIA [mailto:[email protected]]
Sent: Tuesday, February 25, 2003 5:36 AM
To: '[email protected]'
Subject: Serial driver for Linux
Hi all,
I plan to use a NI FieldPoint IO system with EPICS running on a LINUX PC. My
FieldPoint IOs will be connected with RS232 / RS485 interfaces.
I am looking for something equivalent to drvSerial / drvASCII on Linux. Has
somebody already done such development?
Many thanks in advance.
J.F. Gournay
CEA Saclay
DAPNIA/SIS
tel +33 (0)1 69 08 70 32
fax +33 (0)1 69 08 63 01
Prev: ca_put on an IOC Hammonds, John P.
Next: Re: ca_put on an IOC Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Serial driver for Linux GOURNAY Jean-François DAPNIA
Next: RE: Serial driver for Linux Robby Tanner
