1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Commercial RTOS to replace vxWorks
To: tech talk <[email protected]>
Date: 21 Feb 2003 16:23:21 -0500
What about QNX?  I seem to recall that it was available --like Oracle,
Qt and a growing number of other products-- free for personal use, with
a charge for commercial use.
Not my area of expertise, just an observation.
Chris
On Fri, 2003-02-21 at 16:05, Andrew Johnson wrote:
> john sinclair wrote:
> > Are there any plans to move toward a less expensive RTOS replacement for
> > vxWorks? I am interested in RTEMS but would also like to be able to
> > use a commercial product (without having to put up with Wind River).
> RTEMS is available as a commercial product - you can pay oarcorp for
> support if you don't want to do everything yourself.  Currently that's the
> leading alternative to vxWorks for IOCs with real hardware interfaces,
> although I'm personally interested in Jaluna, an open source (but also
> commercially supported) derivative of ChorusOS.  It shouldn't be very hard
> to write the OSI routines to get EPICS running on Jaluna, which provides
> full Posix realtime support and a choice of 3 memory models, although
> nobody's doing this yet. http://www.jaluna.com/
> - Andrew
Christopher A. Larrieu
Computer Scientist, Acc. Controls Group
Thomas Jefferson National Accelerator Facility
Re: Commercial RTOS to replace vxWorks Noboru Yamamoto
Commercial RTOS to replace vxWorks john sinclair
Re: Commercial RTOS to replace vxWorks Andrew Johnson
Prev: Re: Commercial RTOS to replace vxWorks Till Straumann
Next: Re: Commercial RTOS to replace vxWorks Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
