I have a question concerning the use of the function recGblResetAlarms in conjunction with the db_post_events function. In most cases recGblResetAlarms should NOT be called. Let's review what recGblResetAlarms does (It also sets alarm mask but that is not important for this discussion). It sets stat = nsta set status equal to new status sevr = nsev set severity equal to new severity nsta = 0 set new status to 0 nsev = 0 set new severity to 0 What is assummed is that no more alarms will be raised from the time recGblResetAlarms is called until db_post_event is called for any field that the record support process method monitors. recGblSetSevr changes the nsta and nsev fields NOT the stat and sevr fields. If something not connected with processing calls recGblResetAlarms then alarms connected with record processing may be lost. Fritz's question relates to issuing a db_post_event to a field that is not monitored by the record support module. The status and severity that will be associated with the db_post_event will be the status and severity related to the last time recGblResetAlarms was called, i.e. the last time the record was processed. In most cases this should be OK. If the db_post_event is for a field not monitored when the record is processed alarms should not be of interest. For example consider the aiRecord. It has a special routine that looks for field LINR being changed. If it detects a change it also checks to see if ESLO and EOFF change and if they change it calls db_post_event. If a CA client monitors these fields asking for severity and status it will get the status and severity from the last time the record was processed. Thus it could get the old status and severity even though they have changed because the record has started but not completed processing. I will maintain that the CA client should not be asking for status and severity for such fields. If it does it will also receive an event each time the status and severity change. If a record support module has a lot more "state" than normal records perhaps there might be a reason for code other than process to call recGblResetAlarms. But think hard before creating such record support. Marty Kraimer
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
