Wow, this is just what I was going to be looking for shortly.
It tried it and it does the job!
I downloaded a copy for Unix from:
http://www.math.fu-berlin.de/~guckes/screen/dist.php3
> -----Original Message-----
> From: John Maclean [mailto:[email protected]]
> Sent: Wednesday, January 29, 2003 1:29 PM
> To: Kevin M. Peterson; tech-talk
> Subject: Re: Running iocsh in the background
> I had this problem and have used the screen program as
> suggested by Eric
> Norum.
> "screen" is a unix program that may not be on your system but
> should be
> easily available. Our sysadmin people installed it for me
> very quickly.
> It allows you to detach the screen from the ioc without
> killing the ioc.
> You can of course reattach the screen later.
> screen is a program with many options, just consult the man page!
> However some commands that I've found useful are:
> (To simplify things I've assumed "myioc" is a script to start
> the ioc in
> the usual manner)
> screen myioc - this will start the ioc attached to a
> screen. <ctl>a
> <ctl>d will detach the screen, leaving the ioc running.
> screen -ls - will list the active screen sessions
> screen -r pid.tty.hostname - will reattach to the ioc screen.
> ssh -t pid.tty.hostname "screen -R" - reattaches to a screen on a
> remote machine (not sure this is the exact syntax for this one)
> screen -d -m myioc - will start the ioc in detached mode
> <ctl>a d - detaches screen from ioc
> I've found this to be a really neat tool. It even captures
> the console
> output when your screen is detached and you see it when you
> reattach. I
> have a couple of test stands running for our power supply group using
> this technique. There are issues of how you handle multiple
> iocs on one
> machine that I haven't had to consider yet. How do you make sure you
> shut down the correct ioc for example?
> I hope this helps.
> John.
> Kevin M. Peterson wrote:
> > I have a Linux IOC and I am using the main function from
> > R3.14.1's example App. After the IOC is initialized iocsh
> > left in "interactive mode" just like the App. Dev. Guide
> > describes.
> > Unfortunately, "shutting down" the Linux IOC dangerously
> > easy. It isn't necessary to type the "exit" command; Closing
> > the terminal window or pressing Ctrl-C do the job with even
> > less effort.
> > Is it possible to start the Linux IOC and have it run in the
> > background? The Linux IOC seems to be missing the
> > "non-interacting mode" that all of the vxWorks IOCs have.
> > Thanks ahead of time,
> > Kevin Peterson
Re: [Fwd: align CPU Error message????] Leonard J. Reder
RE: Building VxWorks Boot Rom on Linux Singleton, SJ (Stephen)
<2003>
RE: Running iocsh in the background Rarback, Harvey
Problems with "mbufs" on vxWorks Jeff Hill
<2003>
