You have to set LD_LIBRARY_PATH when _running_, not when compiling the 'example' application. Good point. Under LINUX, in order to embed the library path into the executable, you have to Note that setting the SHRLIB_SEARCH_DIRS variable adds the necessary -rpath options. It has only been implemented on Linux though - we should probably do the same thing on all Unix class OSs, but I believe Linux is currently the only OS where we build and use shared libraries by default. I don't like having a manual setting, but some sites need to be able to use different paths at build time and run-time. - Andrew -- A: No, see http://www.netmeister.org/news/learn2quote.html Q: Should I include quotations after my reply ?
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
