1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: base R3.14.1 "example" application booting problem
To: "Eric Norum" <[email protected]>
Cc: "Tech-talk" <[email protected]>
Date: Sat, 25 Jan 2003 13:46:10 +0800
>  The problem is that the
> RTEMS sysconf is being excessivly paranoid about requests for which it
> has no information.
> Here's the patch.
> diff -ur rtems-ss-20021118.orig/cpukit/posix/src/sysconf.c
> rtems-ss-20021118/cpukit/posix/src/sysconf.c
> --- rtems-ss-20021118.orig/cpukit/posix/src/sysconf.c   Thu Sep 13
> 16:04:21 2001
> +++ rtems-ss-20021118/cpukit/posix/src/sysconf.c        Mon Jan 20
> 15:07:16 2003
> @@ -8,6 +8,7 @@
>  #include <time.h>
>  #include <unistd.h>
> +#include <errno.h>
>  #include <rtems/system.h>
>  #include <rtems/score/tod.h>
> @@ -31,6 +32,9 @@
>          return rtems_libio_number_iops;
> +    case _SC_GETPW_R_SIZE_MAX:
> +        return 1024;
>  #if defined(__sparc__)
>      case 515: /* Solaris _SC_STACK_PROT */
>       return 0;
> @@ -40,5 +44,6 @@
>        break;
> -  return POSIX_NOT_IMPLEMENTED();
> +  errno = EINVAL;
> +  return -1;
patched by this patch, still have problems. When booting the "example" application,the following error rise up:
*****Starting EPICS application*****
Exception 13 caught at PC 18119C by thread 167837697
Processor execution context at time of the fault was:
EAX = FFFFFFFF EBX = 24C48C   ECX=63  EDX = 7F5F88C
ESI = 0  EDI = 0  EBP = 43E0B8 ESP=43E08C
Error code pushed by processor itself (if not 0) = 0
***********FAULTY THREAD WILL BE DELETED****************
Then the cpu halt.
regards,
Shao Mingchao
Engineering Physics Department
Tsinghua University
Beijing,100084,China
base R3.14.1 "example" application booting problem, and rdbg questions M.C.Shao
Re: base R3.14.1 "example" application booting problem, and rdbg questions Eric Norum
Prev: StripTool Nick Rees
Next: R3.14.1 ioc example Kevin M. Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: base R3.14.1 "example" application booting problem, and rdbg questions Eric Norum
Next: CPUs Rolf Keitel
