1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: my base download account cann't use
To: "Andrew Johnson" <[email protected]>
Cc: "Tech-talk" <[email protected]>
Date: Wed, 18 Dec 2002 16:38:15 +0800
For now, I'm using base 3.14.0beta2. My ioc is based on the RTEMS-pc386 architecture, when I booting the example EPICS application, I found that the target hardware address was "0xFFFFFF".That's very strange, so the target  couldn't boot. And I know that Eric([email protected]) has boot the example application on i386 with base 3.14.0beta1 successfully. I has been in trouble with this booting problem for several weeks. So I decide to try with base 3.14.0beta1.
And I suspect that this might be a bug in 3.14.0beta2.
So would you please send the source of base 3.14.0beta1 to me? whether or not, thank you very much.
Any suggestions about this booting problem are appriciated.
Shao Mingchao
Engineering Physics Department
Tsinghua University
Beijing,100084,China
----- Original Message -----
To: "M.C.Shao" <[email protected]>
Sent: Wednesday, December 18, 2002 12:38 AM
> EPICS Base version 3.14.0beta1 and earlier 3.14 releases have not been
> released under the new Base license, so it is not available for download
> using your password.  Why do you want a copy of the older version?
> - Andrew
> A: No, see http://www.netmeister.org/news/learn2quote.html
> Q: Should I include quotations after my reply ?
Re: my base download account cann't use Andrew Johnson
Building 3.13Extensions with 3.14 base Problem. Edwin du
Re: Building 3.13Extensions with 3.14 base Problem. Andrew Johnson
Prev: Re: Bug on Pentium IOC Eric Norum
Next: Re: my base download account cann't use Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Building 3.13Extensions with 3.14 base Problem. Andrew Johnson
