1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: jdct run-time error
To: "Ernest L. Williams Jr." <[email protected]>
Cc: "Tech-talk" <[email protected]>
Date: Tue, 10 Dec 2002 21:26:31 +0800
yes, I have built dbStaticJava and set CLASSPATH properly.
Shao Mingchao
Engineering Physics Department
Tsinghua University
Beijing,100084,China
----- Original Message -----
Sent: Tuesday, December 10, 2002 9:21 PM
Make sure that you build dbStaticJava.
Also, make sure that your CLASSPATH environment variable is set properly.
For example,
export CLASSPATH=.:${EPICS_EXTENSIONS}/javalib
SNS Control Systems Group, ORNL
701 Scarboro Rd., MS 6473
Oak Ridge, TN 37830
Phone 865-241-9071
e-mail: [email protected]
Fax 865-574-4799
Sent: Tuesday, December 10, 2002 3:44 AM
Subject: jdct run-time error
hi,all
I have built jdct on RedHat linux sucessfully,but when I try to run it,the following error is encountered:
Exception in thread "main" java.lang.UnsatisfiedLinkError: /usr/local/epics/extensions/lib/linux-x86/libdbStatic.so: /usr/local/epics/extensions/lib/linux-x86/libdbStatic.so: undefined symbol: dbDumpFldDes
        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
        at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1480)
        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1404)
        at java.lang.Runtime.loadLibrary0(Runtime.java:772)
        at java.lang.System.loadLibrary(System.java:832)
        at dbStatic.DbBase.<clinit>(DbBase.java:71)
        at jdct.JdctMenu.<init>(JdctMenu.java:28)
        at jdct.JdctFrame.<init>(JdctFrame.java:43)
        at jdct.Jdct.main(Jdct.java:19)
I have installed java sdk 1.4.0_01, and set the eviroment variable PATH and LD_LIBRARY_PATH properly. what's the proble now?
any suggestions are appreciated.
Shao Mingchao
Tsinghua University
Beijing 100084
P.R.China
jdct run-time error M.C.Shao
Re: jdct run-time error Ernest L. Williams Jr.
Prev: Re: jdct run-time error Ernest L. Williams Jr.
Next: Re: jdct run-time error Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
