1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Building 3.13Extensions with 3.14 base Problem.
To: [email protected]
Date: Thu, 05 Dec 2002 19:29:43 +0800
Hi all,
I was tring to build EPICS R3.13 extensions with R3.14.0beta2 base, host structure
linux-x86, target structure i386-rtems. Base and cross-complier has been built
successfully.
Compiling CA monitor, dct313, Jdct, MEDM is successful, and I have got those
binary files in my $(EPICS_EXTENSIONS)/bin/linux-x86/
But libraries seems not been connected correctly, and I got the following
prompts:
[root@tu032244 linux-x86]# ./camonitor
../camonitor: error while loading shared libraries: libca.so: cannot open shared
object file: No such file or directory
[root@tu032244 linux-x86]# ./medm
../medm: error while loading shared libraries: libca.so: cannot open shared object
[root@tu032244 linux-x86]# ./jdct
java.lang.ExceptionInInitializerError: [exception was
java.lang.UnsatisfiedLinkError: libdbStatic: not found]
	at jdct.JdctMenu.<init>(JdctMenu.java:28)
	at jdct.JdctFrame.<init>(JdctFrame.java:43)
	at jdct.Jdct.main(Jdct.java:19)
	at java.lang.Throwable.fillInStackTrace(Throwable.java:native)
	at java.lang.Throwable.<init>(Throwable.java:38)
	at java.lang.Error.<init>(Error.java:21)
	at java.lang.LinkageError.<init>(LinkageError.java:21)
	at java.lang.UnsatisfiedLinkError.<init>(UnsatisfiedLinkError.java:21)
	at java.lang.Runtime.loadLibrary(Runtime.java:150)
	at java.lang.System.loadLibrary(System.java:143)
	at dbStatic.DbBase.<clinit>(DbBase.java:71)
I have those files in my extensions/lib/linux-x86/ directory:
libANLwidgets.a  libca.a  libcaObject2.a  libca.so  libdbStatic.a  libdbStatic.so
libPrintUtils.a
Is there any instructions for me? Thanks a lot.
Re: Building 3.13Extensions with 3.14 base Problem. Andrew Johnson
Prev: Building 3.13Extensions with 3.14 Base Probelm Edwin du
Next: RE: libezca and EPICS-3.14 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Building 3.13Extensions with 3.14 base Problem. Andrew Johnson
