Subject: |
building capfast with EPICS R3.14.0beta2 |
Kevin Tsubota <[email protected]> |
To: |
"tech-talk (E-mail)" <[email protected]> |
Date: |
Wed, 4 Dec 2002 08:13:03 -1000 |
> I'm having problems building capfast .sch files into .db files.
> I'm using the DB rule and specify the .db I want built based on the
> schematic name, in this case I want tnet.sch built and install as tnet.db.
> However when I do this I get the following error:
> mahaiula:tnetDev> gmake
> perl /usr/local/epics/r3.14.0beta2/base/configure/tools/makeMakefile.pl
> O.solaris-sparc-gnu ../../..
> mkdir O.Common
> gmake -C O.solaris-sparc-gnu -f ../Makefile TOP=../../..
> T_A=solaris-sparc-gnu install
> gmake[1]: Entering directory
> `/home/ktsubota/kroot/kss/epcom/unixIoc/dev/tnetDev/O.solaris-sparc-gnu'
> gmake[1]: *** No rule to make target `../O.Common/tnet.substitutions',
> needed by `../O.Common/tnet.db'. Stop.
> gmake[1]: Leaving directory
> gmake: *** [install.solaris-sparc-gnu] Error 2
> mahaiula:tnetDev>
> I've tried specifying "DB += tnet.edf" and this generates the .edf file
> based on tnet.sch but also
> goes ahead installs it into $(INSTALL_DB), it didn't convert the .edf to
> .db.
> I also specified both "DB += tnet.edf tnet.db" but that gives an error
> saying it can't fine /edb.def.
> Am I using the wrong rule? How do I tell the makefile to take a .sch file
> and make and install a .db file?
> Thank you.
> Kevin Tsubota
> California Association for Research in Astronomy
> W.M. Keck Observatory
> 65-1120 Mamalahoa Hwy.
> Kamuela, HI 96743
> tel: (808) 885-7887
- Re: building capfast with EPICS R3.14.0beta2 Matthieu Bec
Re: Problems with 3.13.7 and PPC604/MV2304 Andrew Johnson
<2002>
<2002>
