1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VDCT groups
To: John Maclean <[email protected]>
Date: Wed, 27 Nov 2002 12:00:09 +0100
I'm using the grouping facility.
But I have no objections to have it turned off by default,
as long as I have a menu item and/or command line option
to turn it on.
The hierarchical scheme is very nice. At a certain point
we should generate an alternative to dbLoadTemplate
that is capable of expanding those sources on the IOC.
But unfortunately it is useless if you want to understand
and modify an old or third party database which is not
using your hierarchies.
And that is for me the only reason to use a graphical
tool in the first place. Therefore I would appreciate if we
could keep the grouping ability for the VisualDCT.
Andreas
John Maclean wrote:
> We are drawing up requirements for future versions of VDCT.
> Based on discussions with a number of people it appears the the grouping
> facility is not used but is often a source of confusion.
> So the question is, should we remove grouping from VDCT? If we don't
> remove it then it will certainly be turned off by default.
> Note that groups are different from the hierarchy scheme that is now
> being implemented. See the user manual at
> http://www.cosylab.com/visualdct/builds/VisualDCT/2.3.1238/doc/MAN-VisualDCT_Users_Manual.html
> if you need more information on groups or hierarchies.
> If no one objects we'll remove grouping.
> John Maclean.
Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002
mailto:[email protected], http://people.web.psi.ch/luedeke
VDCT groups John Maclean
Prev: VDCT groups John Maclean
Next: Re: VDCT groups Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
