1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Channel Watcher V2.0
To: "'Steve Lewis'" <[email protected]>, "'Zelazny, Michael S.'" <[email protected]>
Cc: "'EPICS Tech-Talk'" <[email protected]>
Date: Mon, 18 Nov 2002 10:04:34 -0700
>    -- VxWorks NFS uses UDP; all told there is not much overhead.
> (CA,
> which is very efficient in most respects, uses TCP; and Channel
> Watcher
> may be additionally using NFS to access the file system from
> whichever
> host it is actually runnning on)
A considerable amount of effort has gone into making TCP efficient. This
is especially true in high throughput situations and in situations where
there is network congestion. While similar things can be accomplished
with UDP you are always at a disadvantage because TCP is scheduled
within the operating system, and because TCP is so fundamental that is
has had more research dollars thrown at it. Making and breaking TCP
circuits is not particularly efficient, but after the circuit is
established it is hard to beat. In contrast, I seem to recall that the
implementation of NFS on vxWorks is resource intensive. It uses quite a
bit of stack space, and it uses a lot of dynamically allocated memory.
There is nothing inherently wrong with dynamic memory allocation on
vxWorks. However whenever an action is running periodically that must
repeatedly allocate and free memory then there may be concerns about
memory fragmentation. I seem to also recall reading that NFS was not
particularly efficient in wide area network situations because of less
than optimal packet schedualing, but that may have changed in recent
years.
I completely agree with the goal of distributing the system and thereby
avoiding a single point of failure. However, the NFS server, while
capable of some robust configurations, should probably not be entirely
released from scrutiny when identifying single points of failure.
In a perfect world, the backup and restore data would be maintained in a
battery backed up RAM resident within the IOC. All other boot data would
be maintained in a flash ram also resident within the IOC.
Jeff
RE: Channel Watcher V2.0 Ernest L. Williams Jr.
Re: Channel Watcher V2.0 Steve Lewis
Prev: Re: how about using a new IOC host OS? anj
Next: Re: alarms and autodialers Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Channel Watcher V2.0 Steve Lewis
Next: RE: Channel Watcher V2.0 Ernest L. Williams Jr.
