The Channel Watcher moves the save part of save/restore from the IOC to UNIX. This an old subject. The motivation for the "bumpless" IOC-based approach to save/restore is: -- reduce to a minimum the upset caused by rebooting an IOC while it is being used in an operational facility -- maintain strong EPICS architectural bias against single-point failures and central bottlenecks -- minimize administrative work of synchronizing (multiple, differently formatted) lists of things about channels Bumpless assumes: -- an application suite such as BURT is used to manage grand collections of set-points for initiating and changing how the facility operates, either from a non-operating state or when shifting over -- you have got NFS working well for the usual booting-up process on your IOCs. Bumpless provides: -- a very simple way to mark fields in your database as "bumpless"; just another attribute like PP or MDEL to be naturally managed by the knowledgeable application developer -- it has a few parameters to trade off efficiency with network/IOC loading: how often to save/now much to "batch" saves -- since the single, short file it uses is typically kept on the same file system where the database loads from, the success of the one more or less ensures the success of the other -- VxWorks NFS uses UDP; all told there is not much overhead. (CA, which is very efficient in most respects, uses TCP; and Channel Watcher may be additionally using NFS to access the file system from whichever host it is actually runnning on) -- it is a very small amount of code; it is easily configured in to the IOC initialization; it does not require management of yet another central client service (get/build right code version; make sure it starts/restarts on some server; make sure its to-do list is updated when *ANY* IOC database is changed) Disclaimer: I had a lot of involvement with getting the bumpless capability going (although Bob and Carl and a few others did all the work); and I am working with a very large non-EPICS control system in which almost everything depends on central servers/services.
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
